Hi, dear all.
When pushing collected data to Aggregate (data collected with odkcollect installed on a Samsung mobile device), we got the following error message:
"Error GenericException: Chain validation failed"
In advance, thanks for your help to solve this problem.
Kind regards,
Hi @DAGBEMAMBOU, please fill out the support template.
- What ODK versions are you using?
- What steps can we take to reproduce the problem?
- What you have you tried to fix the problem?
- Anything else we should know or have? If you have a test form or screenshots or logs, please attach.
Hi, dear Yaw.
Many thanks for your reply.
These data were being sending from a remote device to my Aggregate (v1.6.0)
I had adviced the sender to upgrade his installed ODKCollect to one of its latest versions (his installed version was very old (v1.4....)): this has solved the problem and the data are now successfully sent to my Aggregate server.
Thanks again
Kind regards,
Amal
