I've made it all the way through the instructions for AWS installation, but am completely lost on how to actually launch Aggregate for the first time. I'm running into errors whenever I try to use either of the IP addresses that I created through AWS, and also when I try to launch via Tomcat. advice would be greatly appreciated.
ODK Aggregate 2.0
Tomcat 8.5
Amazon Web Services/EC2
MySQL
PuTTY
Windows 10, Dell Latitude
I went through the entire Installing on Amazon Web Services guide, line by line.
When I try to use the Elastic IP or the Public DNS attached to my instance in order to launch ODK Aggregate, I'm unable to to so. Example:
I entered http://3.18.54.153:8080/ODKAggregate/
And received the following error: " This page isn’t working
3.18.54.153 didn’t send any data.
ERR_EMPTY_RESPONSE"
Similarly, I was intending to use the following two lines to try and launch from the command line:
cd C:\Program Files(x86)\Apache Software Foundation\Tomcat 8.5\bin
startup.bat
However, I'm prevented from event changing the directory (I receive an error after the first line)
I'm not a developer, and am using some of these tools for the first time, so please forgive my ignorance in advance!
