Hi there
Janna’s wonderful youtube tutorial (https://www.youtube.com/watch?v=mDokTnjM6Fo&t=518s 1) worked perfectly to get the data from kf.kobotoolbox.org via API into Power BI – thanks so much!
However, it seems that if I add a question/field to my form after the moment of setting up the API, this field is not appearing in Power BI.
Is this normal or a problem in the way Power BI is communicating with kobotoolbox when the power query is done or ...?
Any hint in which direction I need to further investigate would be welcome.
Kind regards
York
