In the latest update to collect, even though I have 'constraint processing
behavior' set to validate upon forward swipe at the end of the form when I
finalize and save odk collect still stops to validate the responses. It
then skips back to any required questions that were skipped. For my actual
deployments this shouldn't be an issue aside from a slight delay when
saving forms, but often when testing forms I skip several time consuming
sections that have already been finalized. Was this an intentional change
in the latest build? I'm running Android 4.4.4 on a Nexus 4.
Jon,
ODK has always validated everything whenever you finalize and save.
Constraints and field requirements must eventually be enforced, after all,
and the point of finalization is the last chance. The setting for
constraint processing behavior only affects swipe behavior: are constraints
enforced at swipe time also, or only at finalization?
Chris
On Fri, Jul 25, 2014 at 3:56 AM, Jon Prettyman wrote:In the latest update to collect, even though I have 'constraint processing
in the latest build? I'm running Android 4.4.4 on a Nexus 4.--
This is likely an issue with the saved settings being corrupted either
during the upgrade to 1.4.3 (an upgrade from 1.4.3 -1041 to 1.4.3 -1042
would not cause this, but if you upgraded from something older (e.g., 1.4),
it might), or, perhaps when your device upgraded to 4.4.4, something
happened to your settings values.
I would re-check your saved settings to make sure the behaviors you want
are selected.
On Fri, Jul 25, 2014 at 3:17 AM, Christopher Robert wrote:Jon,
enforced at swipe time also, or only at finalization?Best,
Chris
On Fri, Jul 25, 2014 at 3:56 AM, Jon Prettyman jonrprettyman@gmail.com wrote:
processing behavior' set to validate upon forward swipe at the end of the
form when I finalize and save odk collect still stops to validate the
responses. It then skips back to any required questions that were skipped.
For my actual deployments this shouldn't be an issue aside from a slight
delay when saving forms, but often when testing forms I skip several time
consuming sections that have already been finalized. Was this an
intentional change in the latest build? I'm running Android 4.4.4 on a
Nexus 4.--
