Dear Sirs et Madames,
There are occasions when the data to be input in the form is just 1 or
2 characters long, yet the input field spans the whole form. Is there
any way of specifying the size of an input field?
Thanks in advance,
Tumaini
Thanks in advance,
Tumaini
No - but you can add a constraint to the field using a bind if you want
to ensure that the string length stays below a certain number of
characters. I believe there should be examples for this elsewhere in
the mailing list or via links on the opendatakit.org website.
Matt Adams
Radical Dynamic
Correct; this level of control is not available. Code contributions welcome.
Hi all,
I recently came across this post and am facing the same problem. Is it
still not possible to adjust the size of an input field?Thanks so much,
Thanks in advance,
Tumaini
Along that vein, you can also specify the space allocated for a string
within the datastore layer; by default, barcode, string and select1 fields
are limited to 255 characters and will be silently truncated upon
submission.
In a form with many questions, specifying a smaller value can significantly
improve the storage efficiency of your database layer; you can also
increase the space being allocated. See:
http://code.google.com/p/opendatakit/wiki/XFormDesignGuidelines#Datastore_String_Length
any way of specifying the size of an input field?No - but you can add a constraint to the field using a bind if you want to
ensure that the string length stays below a certain number of characters.
I believe there should be examples for this elsewhere in the mailing list
or via links on the opendatakit.org website.--
Matt Adams
Radical Dynamic
www.radicaldynamic.com--
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
http://www.OpenDataKit.org
