Hi Guys,
From reading past posts I realize there is really no easy way to change or
update existing forms.
What I am going to do is
Save the current data for the form as a temp fusion table then delete
both the data and old form on Aggregate.
I will upload the new updated form and publish to google fusion with
live stream.
Merge the old (temp) fusion table with the old data with the new google
fusion table.
Just want to know if there are any pointers or better way to do this that
this?
Any advise/pointers appreciated.
Nome
Hi Nome,
It's never a good idea to delete data if you don't have to. Keep the old
form but disable downloads. Add a new form that is enabled. New submissions
will come to that form and you can merge the data in FT.
Need ODK services? http://nafundi.com provides form design, server setup,
professional support, and software development for ODK.
On Thu, Jul 9, 2015 at 3:41 AM, Nomeneta Saili nome.saili@gmail.com wrote:
Hi Guys,
live stream.
fusion table.
this?
Nome
Thanks, Yaw,
Much appreciated.
Congrats on the recent award. Well deserved.
Regards,
Nome
On Fri, Jul 10, 2015 at 1:06 AM, Yaw Anokwa wrote:
Hi Nome,
Hi Guys,
or update existing forms.
live stream.
google fusion table.
this?
Nome
