ODK Aggregate v1.4.3 instance running with a PostgreSQL 9.1 database. With
ODK Collect 1.4.3 (1042) tested on both Android 4.1.2 and 4.4.2.
I an encountering a problem where it seems that if you change the username
and password in "General Settings" that those changes are not put into
effect for any subsequently submitted forms until you hard exit from
Collect and re-open. Here are some steps to follow to replicate my problems.
Start by logging in as "User_1" and download a form.
Fill out a survey and send finalized form.
Go to "General Settings" and change username and password to "User_2"
Running a query shows both submitted forms are from "User_1"
Hard exit out of ODK Collect
Re-open ODK Collect fill out form and submit. You are prompted to enter
username and password, but the username set in Step 3 is already set as
default. Submitted form is now showing "User_2."
Am I changing users correctly? Is the only way for different users to take
effect is to hard exit after changing user in "General Settings?" Thanks.
Interesting. Yes, I have confirmed that this is the way the code was
written -- at start-up, it collects information about the device, user,
etc., and never re-loads that, so even though you change the value in step
3, the change is not seen until ODK Collect is shut down and restarted.
I have created this issue:
http://code.google.com/p/opendatakit/issues/detail?id=1037
Please "Star" it if you want to be notified of any changes/fixes for this
issue. No ETA for a fix.
Great. Thanks for the quick response.
> Mitch
>> With ODK Collect 1.4.3 (1042) tested on both Android 4.1.2 and 4.4.2.
>> username and password in "General Settings" that those changes are not put
>> into effect for any subsequently submitted forms until you hard exit from
>> 1) Start by logging in as "User_1" and download a form.
>> 2) Fill out a survey and send finalized form.
>> 3) Go to "General Settings" and change username and password to "User_2"
>> 4) Fill out a survey and send finalized form.
>> 5) Running a query shows both submitted forms are from "User_1"
>> 6) Hard exit out of ODK Collect
>> 7) Re-open ODK Collect fill out form and submit. You are prompted to
>> enter username and password, but the username set in Step 3 is already set
>> as default. Submitted form is now showing "User_2."
>> take effect is to hard exit after changing user in "General Settings?"
>> Thanks.
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
