After we are done with our survey, we are going to run an audit survey
which will consist of a few questions from the actual survey just to
double check the data.
Is there a way to check if data in Survey2 matches data in Survey1
with the questions being the same.
dump the data to csv and use your favorite analysis tool (python,
spss, tableau, etc) to compare the columns that should be the same.
yaw
On Wed, Nov 2, 2011 at 20:41, Sanjeev Swamy wrote:
> Hi Guys,
> Thank You,
> Sanjeev
