According to the XForms specification:
The choices Element
This element is used within selection form controls to group available
choices. This provides the same functionality as element optgroup in HTML.
I thought this meant that I could use it in a tag like this:
However, this does not work. ODK Collect gives me the error: "select has
no choices".
What am I missing?
m.
odk implements javarosa's subset of xforms. that subset doesn't have
the choices tag.
xform spec: https://bitbucket.org/javarosa/javarosa/wiki/xform
xform tutorial: https://bitbucket.org/javarosa/javarosa/wiki/buildxforms
sample forms: http://code.google.com/p/opendatakit/source/browse/?repo=forms
xform design tips:
http://code.google.com/p/opendatakit/wiki/XFormDesignGuidelines
On Tue, Oct 11, 2011 at 04:02, Matteo Sisti Sette wrote:
> Hi,
> The choices Element
> However, this does not work. ODK Collect gives me the error: "select has no
> choices".
> What am I missing?
> Thanks
> m.
