Ok.
But, the same converted form worked well for you?!
The xls version you attached worked for me but I used the online version. It's very likely that the one you are using is too old and doesn't recognize those new parameters.
ok; I will try and let you know
Many thanks
@Grzesiek2010,
you are right;
many, many thanks.
Cheers,
With the audit file you have attached, how to know if this is for a particular survey? As there is no "UUID/Instance_ID", how we can specify, as multiple surveys will be conducted on the same form and in same day?
