Hi every one
I modify somethings to odk collect, everything its fine, but i cant get the windows map on geopoint apearance "placement-map"
Some ideas??
You need to modify the manifest with new maps key:
<meta-data
android:name="com.google.android.maps.v2.API_KEY"
android:value="AIzaSyBS-JQ-dnaZ_8qsbvSyr_I3rTPFd5fJsYI"/>
And I think you also need to create a auth key to grant it access to Maps
through the project management console (the same way you create keys for
the publishers in ODK Aggregate).
On Wed, Nov 5, 2014 at 5:23 AM, wrote:Hi every one
Some ideas??
Thanks--
I'm kind of new at this, im a little loose about this api thing, where do i
get this api?
El miércoles, 5 de noviembre de 2014 15:06:59 UTC-3, Mitch Sundt escribió: > > You need to modify the manifest with new maps key: > > > android:name="com.google.android.maps.v2.API_KEY" > android:value="AIzaSyBS-JQ-dnaZ_8qsbvSyr_I3rTPFd5fJsYI"/> > > And I think you also need to create a auth key to grant it access to Maps > through the project management console (the same way you create keys for > the publishers in ODK Aggregate). > > > On Wed, Nov 5, 2014 at 5:23 AM, <alanc...@gmail.com > wrote: > >> Hi every one >> I modify somethings to odk collect, everything its fine, but i cant get >> the windows map on geopoint apearance "placement-map" >> Some ideas?? >> Thanks >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >These questions should be asked on the opendatakit-developers@ list.
Please use that list in the future.
opendatakit@ is for people who are not trying to build their own version of
the tools from the source code.
Please recognized that Google != ODK. We are using a public Google API for
rendering maps.
You should therefore try Googling for information on this public API.
i.e., Google for this:
And proceed from there.
On Mon, Nov 10, 2014 at 2:01 PM, Alan Chase wrote:I'm kind of new at this, im a little loose about this api thing, where do
i get this api?El miércoles, 5 de noviembre de 2014 15:06:59 UTC-3, Mitch Sundt escribió:
<meta-data android:name="com.google.android.maps.v2.API_KEY" android:value="AIzaSyBS-JQ-dnaZ_8qsbvSyr_I3rTPFd5fJsYI"/>
the publishers in ODK Aggregate).On Wed, Nov 5, 2014 at 5:23 AM, alanc...@gmail.com wrote:
Hi every one
Some ideas??
Thanks--
Groups "ODK Community" group.
mitche...@gmail.com--
