I've two string prompts (free texts) that expect restricted foods in any
community. I want to validate that these prompts don't allow same food
type. eg. Foodtype1 = 'Fish' and Foodtype2 = 'Fish' which is considered
invalid. I tried to compare two food prompts value
constraint="string(/data/Foodtype1) != string(/data/Foodtype2)"
jr:constraintMsg="Food type already entered!!"/>*
with this, i found that it only works if both the entries are exactly the
same (both has to be in upper/lower case). If Foodtype1 = 'fish' and
Foodtype2 = 'Fish', then the comparision allows the inputs and moves
forward. I could use regex to input only lower cases or upper cases but we
can only use one constraint for a node. Is there a way to go about it. What
could be the work around so that entries like below (1 and 2) can be avoided
and entries like 3 is considered valid.
1. Foodtype1 = 'fish' and Foodtype2 = 'Fish' (invalid)
2. Foodtype1 = 'fisH' and Foodtype2 = 'Fish' (invalid) or any such
combinations of cases.
3. Foodtype1 = 'fish' and Foodtype2 = 'egg' (valid)
I'm pretty sure you can use multiple constraints in a node. Build a small
one question form and test it.
community. I want to validate that these prompts don't allow same food type.
eg. Foodtype1 = 'Fish' and Foodtype2 = 'Fish' which is considered invalid. I
<bind nodeset="/data/Foodtype1" type="string"/>
<bind nodeset="/data/Foodtype2" type="string"
- Foodtype1 = 'fish' and Foodtype2 = 'Fish' (invalid)
- Foodtype1 = 'fisH' and Foodtype2 = 'Fish' (invalid) or any such
- Foodtype1 = 'fish' and Foodtype2 = 'egg' (valid)
Javarosa does not provide a "to-lower-case(${fieldname})" function. I think
that is what you would need.
If you do not need to support arbitrary values, use a select and a
predefined choice list to avoid the spelling and upper/lower case problem.
This will also simplify your data analysis later, since you won't be
dealing with one survey with 'Fish' and a second survey with 'fish', and
have to manually reconcile them later.
And if you have to, you can have an 'other' choice with manual entry. But
having a large list of predefined choices will make everything easier.
If you are absolutely convinced that you must have free-form data entry for
these fields, this is most easily handled through the training of your data
collectors.
type.
invalid. I
we
What
avoided
Thnx Yaw for the suggestion. multiple conditions in the constraint solved
my problem.
> Yaw
> On Wed, Aug 19, 2015 at 3:53 AM, ChangbangMobs <chay...@ptas.com.np > wrote:
> type.
> invalid. I
> the
> we
> What
> avoided
> Groups
> > "ODK Community" group.
> an
