Error: ODK Validate Errors:
XForm is invalid. See above for the errors.
: Invalid calculate for the bind attached to "${v_fcs}" : Couldn't understand the expression starting at this point: .../fcs >=42,'0','͎error')))) in expression if( ${fcs} <=28.4,'3','if( ${fcs} >=28.5 and ${fcs} <=35.4,'2',if( ${fcs} >=35.5 and ${fcs} <42,'1',if( ${fcs} >=42,'0','error'))))
The following files failed validation:
${encuesta_erd_ven}.xml
Result: Invalid
2. What app or server are you using and on what device and operating system? Include version numbers. I am testing in https://getodk.org/xlsform/ and ONA.IO
3. What you have you tried to fix the problem? Review the syntax.
Integer constraint . >=0 and . <=7
calculate fcs (${number1}*2)+(${number2}*4)+(${number3}*3)
calculate v_fcs if(${fcs}<=28.4,'3','if(${fcs}>=28.5 and ${fcs}<=35.4,'2',if(${fcs}>=35.5 and ${fcs}<42,'1',if(${fcs}>=42,'0','error'))))
