I have 4 variables/questions of type integer in my .xlsx file. Let's call the variables A, B, C, D. I use XLSForm then upload the form to ODKAggregate.
I am trying to use relevance conditions to display a question only if A=B and also C=D. I have tried all of the approaches below but all of them have produced results that are equivalent to A=B or C=D. In other words, while I want to see the question only if both conditions are met, I am seeing the question if EITHER condition is met. This is equivalent to providing the Boolean OR rather than the Boolea AND.
1: ${A}= ${B} and ${C} = ${D}
2: (${A}= ${B} and ${C} = ${D})
3: (${A} = ${B}) and (${C} = ${D})
To re-articulate, I am using the below as a relevance criterion where I
have integer variables named A, B, C, and D. I want to see the question for
variable E in all cases EXCEPT where A = B and C = D, i.e. when A=B and
C=D, I do not want to see E. I am using 'and' with two NOT EQUAL statements
but none of the below 5 solutions (expanded since last message) works.
Instead all of the below solutions omit E in ANY case where A!=B, rather
than only in the case when A!=B AND C!=D.
1: ${A} != ${B} and ${C} != ${D}
2: (${A} != ${B} and ${C} != ${D})
3: (${A} != ${B}) and (${C} != ${D})
4: (${A} != ${B} and ${C} != ${D})
5: ((${A} != ${B}) and (${C} != ${D}))
ODKAggregate.
I found a solution via the use of not(). Why this works and != doesn't is a
mystery. The below evaluates the whole compound logic rather than the first
term of the formula:
not(${A} = ${B} and ${C} = ${D})
ODKAggregate.
Hi Brett,
The behavior you are describing is not what i would expect. Are you (or do
you need to be) accounting for nulls in this situation? Often times,
especially with non-equality checks, you need to account for the null as
well. So maybe something like:
${A} != ${B} and ${A} != null and ${B} != null
or something like that.
Otherwise I'd review the data output on the other side of test entry and
see if ${A} and ${B} are actually ending up with the values you think they
are.
Also please note, if they are within a repeat then these checks need to be
formulated a different way. The standard ${} reference format is not valid
for referencing items within repeats (neither from within the repeat nor
from outside of it).
Jason
> a mystery. The below evaluates the whole compound logic rather than the
> first term of the formula:
>>> ODKAggregate.
