Conditional default not working inside a repeat group?
I'm using an if() statement in the calculation column of a question to conditionally provide a default answer. It works outside of a repeat group but not inside.
See this simplified example: conditional_default.xlsx (10.1 KB)
The docs I looked at: https://docs.getodk.org/form-logic/#setting-default-responses
A bug? Expected behavior? I'm doing something wrong?
Hi @danbjoseph,
It works if source ${ask} and target ${my_text} are in the same group inside the repeat. See the updated Form below.
The issue seems to be related to the couple of open javarosa bugs: JV#627 and JV#360
