Can i have a group within group in Xform ?
I want to have sub group in the xform or can single group have more
than one label
Thanks and regards
Vinit
On Aug 26, 12:12 pm, Vinit Sharma wrote:
> thanks a lot ... Awesome :)
> this is what i was looking for!!
> On Aug 26, 11:35 am, Yaw Anokwa wrote:
> > try downloading new widgets form onhttp://opendatakit.appspot.com. it
> > won't be exactly the same as the picture, but use your imagination :)
> > On Fri, Aug 26, 2011 at 09:27, Vinit Sharma wrote:
> > > I download rc and test widget.xml from this link
> > >http://code.google.com/p/opendatakit/source/browse/Widgets.xml?repo=f...
> > > but it doesn't show similer to image as you sent
> > >http://opendatakit.org/wp-content/uploads/2011/07/plotStatus.png
> > > can i get xfrom which have such cases and widget in odk
> > > Post: opendatakit@googlegroups.com
> > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com
> > > Options:http://groups.google.com/group/opendatakit?hl=en
On Tue, Sep 27, 2011 at 14:40, Vinit Sharma wrote:
> Hello all,
> than one label
> Thanks and regards
> Vinit
Sorry i want to ask about multiple question in one screen each have
group label within one parent group like-
section a
enter Number
section b
enter Number
section c
On Sep 27, 5:48 pm, Yaw Anokwa wrote:
> yes. you can have groups inside groups.
> has an example.
> > Hello all,
> > than one label
> > Thanks and regards
> > Vinit
I want to know ODK parser only support English language or it can
support multi language .
what if i give in form like
to or
please help regarding it
Best Regards
Vinit Sharma
On Oct 1, 2:46 am, Yaw Anokwa wrote:
> > 1) I want to ask about multiple questions in one screen for which i
> > made form like below
> >> section a
> >> enter Number
> >> section b
> >> enter Number
> >> section c
> if you want multiple questions per screen, add a
> appearance="field-list" to the group tag surrounding the questions.
> > 2) can i have horizontal input field as list widget for radio button
> > or check box?
> no.
> > 3) in which case String number widget is called?
> String field that uses only numbers (plus a couple extra)
> Takes 0-9, -, +, ., space, and comma
> you can find the examples of what we support athttp://code.google.com/p/opendatakit/source/browse?repo=formsandhttp://opendatakit.appspot.com. the new widgets form has examples of
> what is upcoming in collect 1.1.7.
i want to know that can i use condition for read only property like it
is in case of relevent or constraint
for example i want to set read only property true of input field if
user selects particular option in type select otherwise false
please help with this.
Thanks in advance
> >> section a
> >> enter Number
> >> section b
> >> enter Number
> >> section c
> > or check box?
> no.
> what is upcoming in collect 1.1.7.- Hide quoted text -
> - Show quoted text -
sorry for my earlier post actually i want ask about required property
like can we set particular field required = true if user selects
particular option
as we do in case of relevent or constraint
Any help would be appriciated
Best Regards
Vinit
> >> section a
> >> enter Number
> >> section b
> >> enter Number
> >> section c
> > or check box?
> no.
On Tue, Oct 4, 2011 at 21:42, Vinit Sharma wrote:
> Hello all,
> to lang="chinese"> or
> Best Regards
> Vinit Sharma
>> >> section a
>> >> enter Number
>> >> section b
>> >> enter Number
>> >> section c
>> > or check box?
>> no.
yup. the required attribute looks for true() or false(). if you can
have an xpath expression that returns either value (like the relevancy
conditions) it should work.
On Thu, Oct 27, 2011 at 02:53, Vinit Sharma wrote:
> Hello all,
> particular option
> Best Regards
> Vinit
>> >> section a
>> >> enter Number
>> >> section b
>> >> enter Number
>> >> section c
>> > or check box?
>> no.
