Dear all,
I want to know about the conditional jump like on the selecting particular
answer jump to the specified question and lock the particular question and
make some question mandatory or required .
In the sample form i could only find about the skipping rules.
Thanks in advance
Best Regards
Vinit
vinit,
please check out the following resources. the design tutorial should
be particularly useful. also, the widgets forms in the sample form
repo has examples of conditional branching and required questions.
form guidelines: http://code.google.com/p/opendatakit/wiki/XFormDesignGuidelines
form design tutorial: https://bitbucket.org/javarosa/javarosa/wiki/buildxforms
sample forms: http://code.google.com/p/opendatakit/source/browse/?repo=forms
yaw
On Sat, Aug 20, 2011 at 00:03, Vinit Sharma wrote:
> Dear all,
> Thanks in advance
> Best Regards
> Vinit
Thanks a lot for great help
I just want to ask can i jump to the particular question on the basis
of the answer and can i block more than one question on the answer of
the question
On Aug 20, 8:18 pm, Yaw Anokwa wrote:
> vinit,
> form guidelines:http://code.google.com/p/opendatakit/wiki/XFormDesignGuidelines
> form design tutorial:https://bitbucket.org/javarosa/javarosa/wiki/buildxforms
> sample forms:http://code.google.com/p/opendatakit/source/browse/?repo=forms
> yaw
> > Dear all,
> > Thanks in advance
> > Best Regards
> > Vinit
Vinit:
Questions have a "relevancy" or "skip condition", in the negative. If
the question is not "relevant" then it will be skipped. That can
apply to as many questions as you like. So, you can have an entire
branch of questions not appear if they share the same condition.
Gaetano
> the question
>> vinit,
>> yaw
>> > Dear all,
>> > Thanks in advance
>> > Best Regards
>> > Vinit
Thanks for your quick reply
i still have some query
can i use '&&' operation in "relavent" ? like
<bind nodeset="pregnant" required="true()" relevant="../sex='f'" &&
"../age" < 40 />
where i want to use condition like if the gender is female(f) and her
age is less than 40 than only this particular question should display
can i jump to the particular question say question number 10 on the
answer of particular question
Best Regards
Vinit
On Aug 23, 10:46 am, Gaetano Borriello wrote:
> Vinit:
> Gaetano
> > the question
> >> vinit,
> >> yaw
> >> > Dear all,
> >> > Thanks in advance
> >> > Best Regards
> >> > Vinit
- yes
- no, no jump, just relevancy
> 1) can i use '&&' operation in "relavent" ? like
> "../age" < 40 />
> 2) can i jump to the particular question say question number 10 on the
> Best Regards
> Vinit
>> Vinit:
>> Gaetano
>> > the question
>> >> vinit,
>> >> yaw
>> >> > Dear all,
>> >> > Thanks in advance
>> >> > Best Regards
>> >> > Vinit
It would be great help if you can give some syntax help because i
have seen all the sample forms and the link provided by you but i
couldn't find relevant with and operation
I have tried following ..
1> <bind nodeset="name" required="true()" relevant= ("../
sex='f'" )and( "../interests='music'")/>
2> <bind nodeset="name" required="true()" relevant= ("../
sex='f'" )&&( "../interests='music'")/>
3> <bind nodeset="name" required="true()" relevant= "selected(../
interests, 'music')" and "selected(../sex, 'f')" />
4> <bind nodeset="name" required="true()" relevant= "selected(../
interests, 'music')" &&"selected(../sex, 'f')" />
On Aug 23, 3:30 pm, Gaetano Borriello wrote:
> 1) yes
> 2) no, no jump, just relevancy
> > > "../age" < 40 />
> > Best Regards
> > Vinit
> >> Vinit:
> >> Gaetano
> >> > the question
> >> >> vinit,
> >> >> yaw
> >> >> > Dear all,
> >> >> > Thanks in advance
> >> >> > Best Regards
> >> >> > Vinit
in the tutorial i linked to earlier
(https://bitbucket.org/javarosa/javarosa/wiki/buildxforms), it
explains that the syntax is standard xpath. the example that is used
is as follows:
so, for your example, the following should work.
<bind nodeset="name" required="true()" relevant="../sex='f' and
../interests='music' />
instead of the text match, if sex is a select, "selected(./sex, 'f')"
would work in lieu of "../sex='f'".
if you are having problems, try using absolute paths (i.e., /data/sex)
and ensuring that the values you check for (i.e. f and music) are
correct.
> 1> sex='f'" )and( "../interests='music'")/>
> 2> sex='f'" )&&( "../interests='music'")/>
> 3>
> 4>
>> 1) yes
>> > > > "../age" < 40 />
>> > Best Regards
>> > Vinit
>> >> Vinit:
>> >> Gaetano
>> >> > the question
>> >> >> vinit,
>> >> >> yaw
>> >> >> > Dear all,
>> >> >> > Thanks in advance
>> >> >> > Best Regards
>> >> >> > Vinit
Thank you very much yeah its working now earlier i was not passing
absolute path....
I saw the odk viewer where in menu ' Go to Prompt' which is using
FormHierarchyActivity we can jump to the particular question. But i
want to know that can we jump to the particular question on the answer
of the question as far as i got to know from the code is that all the
time ODKVIEW is returning the view according to the question widget on
the "SHOW NEXT VIEW " in FORM ENTRY ACTIVITY when the event type is
question.
so can you tell me where i should pass form index for the next
question as Mr.Borriello said jump is not possible during binding
> is as follows:
> correct.
> > 1> > sex='f'" )and( "../interests='music'")/>
> > 2> > sex='f'" )&&( "../interests='music'")/>
> > 3>
> > 4>
> >> 1) yes
> >> > >> > "../age" < 40 />
> >> > Best Regards
> >> > Vinit
> >> >> Vinit:
> >> >> Gaetano
> >> >> > the question
> >> >> >> vinit,
> >> >> >> yaw
> >> >> >> > Dear all,
> >> >> >> > Thanks in advance
> >> >> >> > Best Regards
> >> >> >> > Vinit
vinit,
jumping to questions is not supported in xforms and it will not be fun
to bypass this behavior. the go to prompt option you describe can only
jump as far as the form relevancy allows.
as far as where you should pass indexes, we don't provide code-level
support. what i can say is that form indexes are particularly
unpleasant to work with...
yaw
> absolute path....
> question.
>> is as follows:
>> correct.
>> > 1> > > sex='f'" )and( "../interests='music'")/>
>> > 2> > > sex='f'" )&&( "../interests='music'")/>
>> > 3>
>> > 4>
>> >> 1) yes
>> >> > > >> > "../age" < 40 />
>> >> > Best Regards
>> >> > Vinit
>> >> >> Vinit:
>> >> >> Gaetano
>> >> >> > the question
>> >> >> >> vinit,
>> >> >> >> yaw
>> >> >> >> > Dear all,
>> >> >> >> > Thanks in advance
>> >> >> >> > Best Regards
>> >> >> >> > Vinit
I am really thankful to you guys ..
Actually in my college major project ,my guide want me to do
conditional jump so i was stuck to that issue.
He just wants to jump to the particular question on the basis of the
answer
any help would be appreciated
On Aug 24, 12:45 pm, Yaw Anokwa wrote:
> vinit,
> yaw
> > absolute path....
> > question.
> >> is as follows:
> >> correct.
> >> > 1> >> > sex='f'" )and( "../interests='music'")/>
> >> > 2> >> > sex='f'" )&&( "../interests='music'")/>
> >> > 3>
> >> > 4>
> >> >> 1) yes
> >> >> > >> >> > "../age" < 40 />
> >> >> > Best Regards
> >> >> > Vinit
> >> >> >> Vinit:
> >> >> >> Gaetano
> >> >> >> > the question
> >> >> >> >> vinit,
> >> >> >> >> yaw
> >> >> >> >> > Dear all,
> >> >> >> >> > Thanks in advance
> >> >> >> >> > Best Regards
> >> >> >> >> > Vinit
one more thing can i jump to particular group if not the question??
> vinit,
> yaw
> > absolute path....
> > question.
> >> is as follows:
> >> correct.
> >> > 3>
> >> > 4>
> >> >> 1) yes
> >> >> > >> >> > "../age" < 40 />
> >> >> > Best Regards
> >> >> > Vinit
> >> >> >> Vinit:
> >> >> >> Gaetano
> >> >> >> > the question
> >> >> >> >> vinit,
> >> >> >> >> yaw
> >> >> >> >> > Dear all,
> >> >> >> >> > Thanks in advance
> >> >> >> >> > Best Regards
> >> >> >> >> > Vinit
again, there is no concept of jumping in xforms. you can make a group
relevant based on previous answer. for example, you can have a
pregnancy group of questions that appear only when
gender is female.
>> vinit,
>> yaw
>> > absolute path....
>> > question.
>> >> is as follows:
>> >> correct.
>> >> > 1> > >> > sex='f'" )and( "../interests='music'")/>
>> >> > 2> > >> > sex='f'" )&&( "../interests='music'")/>
>> >> > 3>
>> >> > 4>
>> >> >> 1) yes
>> >> >> > > >> >> > "../age" < 40 />
>> >> >> > Best Regards
>> >> >> > Vinit
>> >> >> >> Vinit:
>> >> >> >> Gaetano
>> >> >> >> > the question
>> >> >> >> >> vinit,
>> >> >> >> >> yaw
>> >> >> >> >> > Dear all,
>> >> >> >> >> > Thanks in advance
>> >> >> >> >> > Best Regards
>> >> >> >> >> > Vinit
Ok thanks so i came to know that i can't jump to the particular
question .
one more thing i want to know that can i use table like if xform has
table of radio buttons (multiple rows having control horizontally )so
can the java rosa parse it
> gender is female.
> >> vinit,
> >> yaw
> >> > absolute path....
> >> > question.
> >> >> is as follows:
> >> >> correct.
> >> >> > 1> >> >> > sex='f'" )and( "../interests='music'")/>
> >> >> > 2> >> >> > sex='f'" )&&( "../interests='music'")/>
> >> >> > 3>
> >> >> > 4>
> >> >> >> 1) yes
> >> >> >> > >> >> >> > "../age" < 40 />
> >> >> >> > Best Regards
> >> >> >> > Vinit
> >> >> >> >> Vinit:
> >> >> >> >> Gaetano
> >> >> >> >> > the question
> >> >> >> >> >> vinit,
> >> >> >> >> >> yaw
> >> >> >> >> >> > Dear all,
> >> >> >> >> >> > Thanks in advance
> >> >> >> >> >> > Best Regards
> >> >> >> >> >> > Vinit
we have an upcoming widget in 1.1.7 which gives you yes/no/maybe radio
buttons in a list (see
http://opendatakit.org/wp-content/uploads/2011/07/plotStatus.png). that's
about as close as we get to matrixes.
question .
gender is female.
vinit,
yaw
absolute path....
answer
the
on
question.
used
is as follows:
'f')"
/data/sex)
correct.
i
"selected(../
"selected(../
- yes
form guidelines:
sample forms:
- can i use '&&' operation in "relavent" ? like
"../age" < 40 />
and her
display
- can i jump to the particular question say question number
10 on the
Best Regards
Vinit
Vinit:
negative. If
can
entire
condition.
Gaetano
the basis
answer of
the question
vinit,
tutorial should
sample form
questions.
form guidelines:
sample forms:
yaw
Dear all,
rules.
>> >> >> >> On Tue, Aug 23, 2011 at 2:42 AM, Vinit Sharma < vinit2...@gmail.com> wrote:
>> >> >> >> > On Aug 23, 10:46 am, Gaetano Borriello < gaet...@cs.washington.edu> wrote:
>> >> >> >> >> On Mon, Aug 22, 2011 at 9:52 PM, Vinit Sharma < vinit2...@gmail.com> wrote:
>> >> >> >> >> >> On Sat, Aug 20, 2011 at 00:03, Vinit Sharma < vinit2...@gmail.com> wrote:
>> >> >> >> >> >> > Thanks in advance
>> >> >> >> >> >> > Best Regards
>> >> >> >> >> >> > Vinit
I saw the odk 1.1.7 beta version which you uploaded
may i know when i can see the widget
you can see the widget now if you download the rc and try out new
widgets form. we will push a final release when the rc is stable.
On Fri, Aug 26, 2011 at 08:32, Vinit Sharma wrote:
> I saw the odk 1.1.7 beta version which you uploaded :)
I download rc and test widget.xml from this link
http://code.google.com/p/opendatakit/source/browse/Widgets.xml?repo=forms
but it doesn't show similer to image as you sent
can i get xfrom which have such cases and widget in odk
try downloading new widgets form on http://opendatakit.appspot.com. it
won't be exactly the same as the picture, but use your imagination
thanks a lot ... Awesome
this is what i was looking for!!
On Aug 26, 11:35 am, Yaw Anokwa wrote:
> try downloading new widgets form onhttp://opendatakit.appspot.com. it
> won't be exactly the same as the picture, but use your imagination :)
> >http://code.google.com/p/opendatakit/source/browse/Widgets.xml?repo=f...
