Hi list,
I tried the 'or' operator for two fields but it does not work
Example I wanted a field to not show up until I have to variables
${var1} = 'value' or ${var2} = 'value'
Does anyone have a link to details on operators?.
Nome
Hi list,
Nome
Nome,
'or' works. There must be an another issue with your form. Make a 1
question form and try or.
http://www.w3schools.com/xpath/xpath_operators.asp
On Mon, Jul 27, 2015 at 6:46 AM, Nomeneta Saili nome.saili@gmail.com wrote:
Hi list,
Nome
Hi Nome,
There are two things you can try:
(1) replace = for , e.g.: replace ${var1}='value' by ${var1},'value'
(2) add brackets: (${var1}, 'value' or ${var2},'value')
Good luck!
Anja
A mistake I made early in form building, which could be the cause of your
issue, is not knowing that the relevant fields need to use the syntax of
"selected(${Var},"1")" if it is referring to a "select_multiple" question.
If you use the ${Var}=1 syntax for a "select_multiple" it won't always
function as expected.
Thank you so much guys/gals. Will try it out thanks.
function as expected.On Monday, July 27, 2015 at 7:46:40 AM UTC-4, NMZ wrote:
Hi list,
Nome
