Hello
I'm having trouble configuring a letsencrypt cert with Aggregate and nginx.
First I installed Aggregate (no cert) on tomcat8 on default port (8080) then installed enketo/nginx as per instructions skipping the ssl part: https://blog.enketo.org/install-enketo-production-ubuntu/ and redirected 127.0.0.1:8080/ODKAggregate to /odk in nginx sites-available/enabled
This configuration works and I can use mydomain.com/odk with Collect no problems.
Then I followed the enketo instructions to make a csr and use it with certbot and got three files:
0000_cert.pem, 0000_chain.pem and 0001_chain.pem.
I exported the cert with:
CERT_NAME=0000_cert
openssl pkcs12 -export -in $CERT_PATH/$CERT_NAME.pem -inkey $CERT_PATH/$CERT_NAME.key -out $CERT_PATH/$CERT_NAME.pfx
chmod 644 $CERT_PATH/$CERT_NAME.pfx
chown root:ssl-cert $CERT_PATH/$CERT_NAME.pfx
usermod -a -G ssl-cert tomcat8
and added to server.xml
sed -i.sslold -e '/<!-- Define an AJP/ i <Connector port="8443" protocol="HTTP/1.1"
maxThreads="150" SSLEnabled="true" secure="true" scheme="https"
clientAuth="false" sslProtocol="TLS"
keystoreFile="'"$CERT_PATH"'/'"$CERT_NAME"'.pfx"
keystoreType="PKCS12"
keystorePass="somepass" />'
-e 's//
/' /etc/tomcat8/server.xml
then I updated sites-available/enabled with this: https://drive.google.com/open?id=0ByT05oAp7x21VkhPU3hpQ0w5TG8
next I re-run the Aggregate installer with the ssl option (port 8443) and copy the war to webapps
finally restarted tomcat and nginx
When I go to mydomain.com/odk everything seems fine I get redirected correctly to https://mydomain.com:8443/ODKAggregate I can upload forms, change users, etc. but when I put mydomain.com/odk in Collect I get "trust anchor for certification path not found while accesing https://mydomain.com/odk/FormList".
I can't use Formuploader neither I get "Starting url: http://mydomain.com/odk/upload unexpected exception: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target" I tried with http/https/https:8443
Enketo isn't working either I get this results:
with http://mydomain.com:8025/enketo/api/v1 I get redirected but secure connection failed
with http://mydomain.com/enketo/api/v1 I get this
every other combination gets: "There was an error obtaining the webform"
Also the ssllabs test says: "This server's certificate chain is incomplete. Grade capped to B." How can I fix this?
I'm using Aggregate 1.4.14, Collect 1.9.1 and FormUploader 1.4.9
I tried to follow this https://community.letsencrypt.org/t/nginx-incomplete-certificate-chain/29388 but not sure which files should I concat and if I should replace cert.pem with it. Also most of the questions use apache and no csr so filenames are different.
I added this to my conf file but didn't work:
ssl_trusted_certificate 0000_chain.pem
ssl_trusted_certificate 0001_chain.pem
The altnames for the cert are: mydomain.com and www.mydomain.com. Do I need also mydomain.com/odk, etc.?
I'm using aws if I remove the inbound rules for 8080 and 8443 will nginx still redirect correctly?
