I'm wondering how to connect ODK with Excel and get data into Excel, which URL should I use!!!.
usually, I connect excel with KOBO-API by adding API URL in Excel get data from web
Thanks A.N.M_AL-IMRAN
I already collected data, but I need import data directly from server into Excel using API URL, in Excel there is choice to get data from web
Hello @Haitham_Darweesh ,
The data you have collected must be stored in Aggregate server only right?. If it is aggregate server then in the aggregate server you will have an option of data export. You can export your data in ".csv" format . Hope that helps
