Dear All
Need some help with a constraint to force surveyor to enter a telephone
number in the following format with no spaces.
+27xxxxxxxxx e.g. +27116784567
Bash
Dear All
Bash
This would be a string field ( telephone numbers cannot fit in an int ).
Use an appearance="numbers"
to force the numeric keyboard.
constraint = " string-length(.) = 12 and regex(.,'^+27[0-9]+$') "
you might also be able to just do:
constraint = "regex(.,'^+27[0-9]{9}$')"
See http://docs.oracle.com/javase/7/docs/api/java/util/regex/Pattern.html
for the details.
Dear All
number in the following format with no spaces.+27xxxxxxxxx e.g. +27116784567
Bash
<http://www.avast.com/>This email is free from viruses and malware because avast! Antivirus
http://www.avast.com/ protection is active.--
Hi
I have tried both formats with no success. I have also tried the following with no success, my regex is very bad L
constraint = "regex(^(?:(?:(|)0|+27|27)(?:1[12345678]|2[123478]|3[1234569]|4[\d]|5[134678])(?
| |-|)\d{3}(?: |-|)\d{4}$)"
Dear All
Need some help with a constraint to force surveyor to enter a telephone number in the following format with no spaces.
+27xxxxxxxxx e.g. +27116784567 tel:%2B27116784567
Bash
This email is free from viruses and malware because avast! Antivirus http://www.avast.com/ protection is active.
Unsubscribe: opendatakit+unsubscribe@googlegroups.com mailto:opendatakit%2Bunsubscribe@googlegroups.com
This email is free from viruses and malware because avast! Antivirus protection is active.
Bashir,
Mitch's regex works great for me.
The XML should look like:
This passes:
+27123456789
This doesn't:
+2712345678
You can confirm with http://rubular.com.
On Fri, Jun 20, 2014 at 4:16 AM, Bashir Jahed admin@osilab.net wrote:
Hi
with no success, my regex is very bad Lconstraint =
| |-|)\d{3}(?: |-|)\d{4}$)"Dear All
Bash
mitchellsundt@gmail.com--
Options: http://groups..google.com/group/opendatakit?hl=en
http://groups.google.com/group/opendatakit?hl=en
Thanks All
Got it to work, strange error with the actual spreadsheet I was using, I created a new form and it works, so will just transplant the info from broken excel file to new one.
Bash
Bashir,
This passes:
+27123456789
This doesn't:
+2712345678
Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
Hi
Dear All
Bash
Options: http://groups..google.com/group/opendatakit?hl=en http://groups.google.com/group/opendatakit?hl=en
