The form is asking time spend in each activity. So at the end of the group
I am calculating the total time, time remaining (fixed value - total time).
So if the remaining time is less than 0 I don't want the enumerator to go
forward but instead give an error message and correct the values so that
time remaining isn't less than 0. How should I use constraint in this ?
Add a constraint of "${time_remaining} >= 0" on the prompt where you
want to see that constraint. If that doesn't make sense, try the
simple example at http://xlsform.org/#constraints.
On Fri, Nov 25, 2016 at 2:55 PM, Varun Kumar wrote:
> The form is asking time spend in each activity. So at the end of the group I
> am calculating the total time, time remaining (fixed value - total time). So
> Please any help is really appreciated.
> Thanks,
> V
> "ODK Community" group.
I'm displaying the time_remaining with a note type variable when the group
ends (begin group -> input time -> end group -> calculate -> note type
display approach).
So should I add the constraint at the note type or calculate type. ?
I did add the constraint but still it allows me to go forward. PFA
screenshots of the form with constraints as displayed in the xls.
Please and help is really appreciated. I'm just a beginner.
On Saturday, 26 November 2016 12:34:16 UTC+5:30, Yaw Anokwa wrote:
> Hi Varun,
> Yaw
> group I
> time). So
> > Thanks,
> > V
> Groups
> an
On Sat, Nov 26, 2016 at 10:05 AM, Varun Kumar wrote:
> Hi Yaw,
> Thanks for the reply.
> display approach).
> Thanks,
> Varun
>> Hi Varun,
>> Yaw
>> > group I
>> > time). So
>> > Thanks,
>> > V
>> > Groups
>> > an
>> > email to opendatakit...@googlegroups.com.
