I wrote:
selected(${oeildroit_actif},'4')
not:
selected(${oeildroit_actif}='4')
Your formulas are incorrect. If you are using the XLSForm executable, you
should also use ODK Validate (
https://opendatakit.org/downloads/download-info/odk-validate-2/ ) to
verify the correctness of the form (this is automatically done when using
the web-based XLSForm tool). This would have reported an error with your
form.
The function, selected(X,Y), returns true if the field X had the value Y
chosen among its multiple-choice selections. It returns false otherwise.
There is no '='
Use this function for all tests of the values of all multiple-choice
questions.
Using '=' for those tests will fail if two or more choices are selected.
i.e.,
${oeildroit_actif} = '1' or ${oeildroit_actif} = '2'
will fail if you were to select both 1 and 2.
But
selected(${oeildroit_actif},'1') or selected(${oeildroit_actif}, '2')
will work if you select either 1 or 2 or 1 and 2 together (or along with
any other options in the multiple-choice question).
On Sat, Mar 14, 2015 at 5:17 AM, Whitney whitney.goldman@gmail.com wrote:
Hi Mitch,
Thanks for your reply, but I think I am a bit lost.
For the constraint I want to write, there is a multiple select option as
a first question (please check all of the appropriate disease signs). The
name of the choices are: 1, 2, 3, 4, 9 and 99.
For the following question, it is only relevant if the previous answer
is: either '3' (by itself), '4' (by itself), or '9' (by itself), or if
both '4' and '9' are chosen together.
Everything worked well, except for if '4' and '9' are chosen together. I
can't seem to write the constraint in such a way that the following
question appears if these two are selected together using this constraint:
${hhconsnt}='1' and ${presence}='Present' and ${TRA_SIGN}='1' and
(${oeildroit_actif}='3' or ${oeildroit_actif}='9' or ${oeildroit_actif}='4'
or (${oeildroit_actif}='4' and ${oeildroit_actif}='9'))
I've re-written the constraint according to how I think I understand your
message. It now looks like this:
(${hhconsnt}='1' and ${presence}='Present' and ${TRA_SIGN}='1') and
or ((selected(${oeildroit_actif}='4')) and
(selected(${oeildroit_actif}='9'))))
It uploads to the tablet fine, but when I try and advance through the
questionnaire, this error message shows on the screen of the tablet:
[image: Displaying Screenshot_2015-03-14-12-08-55.png]
Any help would be greatly appreciated. Thank you!
On Friday, March 13, 2015 at 1:44:46 PM UTC-4, Mitch Sundt wrote:
Constraints involving values of select-multiple questions always require
the use of the selected(field,value) function.
so if you wanted to test if ${oeildroit_actif} has the value '4', you
would write:
This returns true if '4' is among the choices selected, and false
otherwise.
Note that the choice names are string values (i.e., the string '4', not
the number 4) and that the set of selected names are stored as a
space-separated sequence of names. Because of this, choice names should
never contain spaces.
On Thu, Mar 12, 2015 at 1:07 PM, Whitney whitney...@gmail.com wrote:
Hi all,
i know this is everyone's favorite topic! I am having some trouble
with writing the constraint for a previous select multiple question . Here
is what I have so far (the part in yellow is what doesn't work when I
download the form and try to implement the logic on the tablet). I
appreciate your help! Thank you!
Whitney
I also tried this, but it didn't work either:
or ((selected${oeildroit_actif}='4' and (selected${oeildroit_actif}='
9'))))
I've attached the Excel file, in case that is also helpful.
A huge thanks in advance,
Whitney
Groups "ODK Community" group.
mitche...@gmail.com
https://groups.google.com/d/topic/opendatakit/gAqdLvZI62U/unsubscribe.
