(1) I want to constrain a text response variable to 200 characters (including spaces). In the constraint column I put: string-length(.)<=200 and regex(.,"[A-Za-z().',]{1,200}")
When I go to fill in the text response I can put as many characters as allowed, but no spaces - an error message pops up saying response invalid -- even though I put a constraint message to say 'answer limited to 200 characters'
(2) when I use ** ** around text it isn't being bolded in the the survey on the tablet I am using
These issues are seen in ODK Collect (latest version) and KOBOcollect on Samsung Galaxy Tab Active2, Android Version 9
searching the forum for advice - couldn't locate a topic that matched the issue I was having. Searching through the ODK website to find the correct code for the xls form.
Advise on the correct constraint message to limit a text string response including spaces, letters, numbers, punctuation to 200 characters.
Advise on why my constraint message from my column 'constraint_message' isn't showing up.
Advise on why ** ** isn't highlighting my text (in the label column) in the survey
