Can anybody help me in defining the condition for below scenario?
I have 2 question
Q1 Gender (select_one gender) (gender is, female=1, male=2)
Q2 Type (select_one benType) (benType is, Plw=1, Child >6 and <24=2 and
Child 24 to <59 =3)
I want constraint in which if a user selects male system should not allow
selecting PLW in the second question.
if (q=2 ,"PLW can't be male", "blank").
Imran,
You should use choice_filter to determine your options in select menus.
Here is an example that uses the selection of a state to filter the options:
Similar logic can be used to get your answer
> I have 2 question
> Child 24 to <59 =3)
