Quick question - results are ordered by capture order by default. is it
possible to apply order by criteria so you can for example order by
surname, or order by date captured etc
looked through some of the examples but can't see anything that shows this
Andrew
As far as I remember, default return order is unspecified. It might be
returning results ordered by capture date, but since that isn't part of the
API it is subject to change. If you require a certain order (be it capture
date or something else), I'd recommend ordering the results yourself.
I believe currently it is recommended to do this in JavaScript. I normally
turn the TableData objects returned by control.query() into an array (using
a for loop). At that point I have all the handy Array methods available,
like sort(), forEach(), etc. If you have vast amounts of data this might
not be a good idea, but for most cases it should be fine.
One of the things being considered with the new API is how much SQL should
be exposed to callers. If you have opinions about what functionality you'd
like to see in the API, let the team know.
Andrew
thanks Sam...will look at js based sorting
> On Thu, Dec 17, 2015 at 1:02 AM, Andrew de Klerk <andrew....@gmail.com > wrote:
>> Thanks
>> Andrew
>> "ODK Community" group.
This link has some good examples of how to do it:
normally turn the TableData objects returned by control.query() into an
array (using a for loop). At that point I have all the handy Array methods
available, like sort(), forEach(), etc. If you have vast amounts of data
this might not be a good idea, but for most cases it should be fine.
should be exposed to callers. If you have opinions about what functionality
you'd like to see in the API, let the team know.
this
Andrew
Groups "ODK Community" group.
