Hi Good people,
I have created a form and I keep getting the ODK validate error. Here is the error message Error: b'ODK Validate Errors:\n>> Something broke the parser. See above for a hint.\nDependency cycles amongst the xpath expressions in relevant/calculate\n\nResult: Invalid'
I would like your help to go through the form and identify where the problem is. I have been at it for hours now and I keep coming back with nothing.
Please check line 692. The name is othergoth, and the relevant for that line refers to itself ${othergoth}=1.
The way I found it was just by noting that the error mentioned a dependency cycle in relevant. So I just deleted the relevant column to be sure, and found that the error was no longer there. Here was my process of elimination:
I then just started deleting chunks of "relevant" formulas to narrow it down. For example, I deleted all relevant formulas from rows 500-900, and there was no error.
So I knew the error was in those rows.
Then I undid that, and deleted relevant formulas in rows 700-900.
The error was still there, so that told me the error was somewhere between row 500-700.
One more test told me the error was somewhere between row 600 and 700.
Then I just took a look at those relevant formulas, and found the problem in line 692.
