Converting XLform offline
Evening Forum, I am trying to convert my XLform offline, and I have received the following error message "ODK XLSForm Offline Warnings: The following language declarations do not contain valid machine-readable codes: English
Have you tried online? If the conversion doesn't work online, try to convert online. The online converter also allows you to preview the form on Enketo form viewer.
Hope this helps!
Check out http://xlsform.org/en/#multiple-language-support and https://docs.opendatakit.org/form-language/ for more details about using multiple languages in a form.
If you are defining multiple languages in your form you should follow the format
label::language1 (code)
for example
label::english (en)
If you only have 1 language in your form, you should be able to safely ignore the warning.
thank you so much, this is helpful.
