Copy from another form in Build
I have a new form using part of the old form so I just copied the old form
and make modification by adding and remove fields. I noticed that even the
skip logic removed from the Relevant in Advance it still appear in xml
file. this caused some of the questions doesn't show up but when you check
the Relevant in Build , there is no restriction. How can I fix this
problem?
wen
Wen,
This sounds like a bug in Build. You can file it at
https://github.com/clint-tseng/odkbuild/issues, but Clint (the dev) is
pretty busy, so I doubt he'll get to it soon. Might be best to move to
XLSForm.
ยทยทยท -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
skip logic removed from the Relevant in Advance it still appear in xml file.
this caused some of the questions doesn't show up but when you check the
Relevant in Build , there is no restriction. How can I fix this problem?
wen
