Hi all,
I'm trying to set up a calculation that gives me the number/count of a possible entry into a string field across repeat groups. Can anybody share the proper xlsform language to do this?
Thanks!
[attached is example .xls]
fh_experiment_book_6.xlsx (13.3 KB)
Can't think of a good way to do this for an arbitrary number of
repeats. You could use index-repeated to count up to a fixed number of
repeats that have the value you want.
On Sat, Jul 26, 2014 at 10:57 PM, igardner@tns.org wrote:
Hi all,
Thanks!
One trick I've seen used a lot is to have an if(some condition, 1, 0)
inside the repeat, then take a sum() outside the repeat. That will give you
a count of the number of times the condition was true inside the repeat.
Not sure if that works in this case, but it might.
Chris
Hi all,
Thanks!
I'm having a similar problem. What command do I use inside what field of XLSForm to be able to count the number of times a condition was true inside a repeat? I've tried everything I can think of and am at a loss... Please help!
Jacquie
On Monday, July 28, 2014 at 9:13:08 AM UTC-4, Christopher Robert wrote:
> One trick I've seen used a lot is to have an if(some condition, 1, 0) inside the repeat, then take a sum() outside the repeat. That will give you a count of the number of times the condition was true inside the repeat. Not sure if that works in this case, but it might.
> Best,
> Chris
> Yaw
> On Sat, Jul 26, 2014 at 10:57 PM, wrote:
> > Hi all,
> > Thanks!
> > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
Suppose that you want to count a number of women in a family. Each repeat
stands for a member and you ask for each member his sex.
- you have to create a calculed variable cond1
- put in the calculation column this formula: if(sex='2',1,0). We assume
that the value label of sex means woman .
- after the repeat group, you calculate and another variable cond2 and on
its calculation column you put this formula:sum(${cond1})
Try this
help!
Jacquie
Chris
On Sat, Jul 26, 2014 at 10:57 PM, igar...@tns.org wrote:
Hi all,
Thanks!
Hi all,
This has worked for me,
count(${Name of the repeat}[condition based on a field]). I used this for counting how many households are below 18 years, this was done out of the repeat, and the group in which that repeat was.
count(${DC}[age< 18])
