I am wondering if there is a way to create a ODK Collect settings template, that will apply to all newly created users. I am trying to run a system, where each worker has an app user created for them, which includes their name and last name. Creating app users in ODK Central is fine, but they get a new QR every time. The thing is, there are some options I want disabled by default on the ODK Collect, but don't want to go through the settings for each and every worker. I saw you can generate a code in the ODK Collect app, but I don't see how it's possible to create a new user out of this, since the ODK Collect instance then just becomes the other app user.
Hopefully I have made my problem clear. I will be extremely grateful for any ideas on how to go about this issue.
If you're comfortable using Python this script from @LN will take a series of names, provision App Users for them, and build a PDF of configuration QR codes for them.
@mapo we hope to eventually make the QR codes configurable from Central. We're not sure when that will happen, though. For now @danbjoseph is right that your best bet is scripting the QR code and/or App User creation.
I have now updated that gist to use pyodk which is now available. I put some example settings in my script, you can configure any of the available settings by referencing the documentation.
