I am trying to generate unique id by using dob, name and part of contact number. I managed to achieve as the local form and having the following challenges:
I need the dob as a string, not as date format
I want to ensure that all letters of the first name should be all caps or all small
I want to pick the last 4 digits from the contact number
First thing: "Where" do you need the unique ID? On ODK collect (meaning on the handset), it doesn't make sense (because you may not check other handsets for uniqueness). If on the aggregate dashboard, you already have META-INSTANCE-ID as the unique ID. If on custom dashboard, there are countless ways to make unique IDs.
Maybe you could explain it a bit more for our understanding.
This unique identifier is a project requirement. Previously I used other ways of generating unique IDs. However this is what I have been assigned to do.
There is no function to convert text to uppercase so I think you need to use regex to force your enumerators to use only capital letters passing first name.
Hello @Grzesiek2010 and @A.N.M_AL-IMRAN,
there might be a workaround to get automatic upper conversion, using absolute path reference. See example. Upper01.xlsx (12.7 KB)
In KoBoCollect, the conversion happens seems to happen on save (see re-edit).
Before save
