I trying to build a form that collects data using nested group_repeat and select_multiple questions however the form is misbehaving at a critical point.
The scenario is as follows:
I want to capture information on where and how many people have been affected by a specific event. Therefore I have an event group repeat that allows the user to input the number of events that affected the country in a specific year. Inside the event group repeat I want to have the information disaggregated by province and I am using a select_multiple question which allows the respondent to select the provinces that have been affected by the event. By selecting the provinces, the form generates a new group_repeat (inside the event group repeat) that is going to repeat the question to all the selected provinces. Afterward, I want to disaggregate the information for the districts inside the province. To do that I created a new group_repeat that is going to ask the questions based on the districts that belong to the current iteration (position/province). Everything seems to work very well when I select only one province. It allows me to select the districts and populate information for each district that was selected. However, if I select two provinces the form doesn't allow me to select the districts for the provinces I have selected.
If you want to reproduce the issue, run the form, select yes continue/"Sim Continue". Select a Year. input number of events (you can try with 1) in Quantos eventos de desastre afectaram Moçambique em 2001? question. Go down and select one province in Selecione as provĂncias que foram afectadas pelo evento question. [you should see the district list at the bottom of the form]. Select the districts in Selecione os districtos da provĂncia de Inhambane que foram afectados question and you will see how the form should work if it was working fine.
Now, go back to Selecione as provĂncias que foram afectadas pelo evento and select an additional province, you will see that the Selecione os districtos da provĂncia de Maputo que foram afectados question will no longer show the options.
I have tried to play with selected-at function in the choice_filter but with no success. I am stuck and out of ideias.
Kobo Questionaire - SandBox.xlsx (58.5 KB)
- Form is here
I am unable to submit screen shots as I am a new user.
