Current() in a choice filter doesn't work
I am using repeat in xlsform, when I use current()/ it works for printing the select_one choice but when I use it inside a choice filter it won't work.
Please advice,
What versions of ODK Collect and XLSForm are you using? What is the behavior you see? What do you expect?
