Hello,
One of our client need to overlay some custom data(layer as a KML or KMZ or shapefile etc.) on the google map of ODK collect.
so how to do that ,..pl give me suggestion .
Rahul
Hello,
Rahul
That is a pretty loaded question.
You would have to parse a KML to get the objects then create objects that
will display on a google
map: https://developers.google.com/maps/documentation/android/marker
So when the map loads, you parse the KML file on the device to load the
objects. Quite a bit of customization on ODK Collect to get this to happen.
Thanks for your reply !
I have done googling but not find exact what i want .
Can you give a simple example how to parse KML to display it on Android Map.
Thanks in Advance
Rahul
Geoodk might be of use or a good reference to you
that will display on a google map:
https://developers.google.com/maps/documentation/android/markerSo when the map loads, you parse the KML file on the device to load the
objects. Quite a bit of customization on ODK Collect to get this to happen.On Wednesday, July 16, 2014 2:18:03 PM UTC-6, rahulgu...@gmail.com
wrote:Hello,
RahulThanks for your reply !
Map.Thanks in Advance
Rahul--
"ODK Developers" group.
You would have to parse a KML to get the objects then create objects that will display on a google map: https://developers.google.com/maps/documentation/android/marker
So when the map loads, you parse the KML file on the device to load the objects. Quite a bit of customization on ODK Collect to get this to happen.
On Wednesday, July 16, 2014 2:18:03 PM UTC-6, rahulgu...@gmail.com wrote:Hello,
Rahul
Thanks in Advance
Rahul
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
Thanks sir for your suggestion.
GeoODK Collect - really good application ,..but i am facing some problem in this app:
GeoODK throw error "GeoODK has unfortunately stopped" when i used appearance="maps" in odk forms (in GeoMap activity widget).
Also got same error when i use my own Map tiles .
Pl. need your suggestion on this matter.
Rahul
Rahul,
Please ask about GeoODK issues on their mailing list:
https://groups.google.com/forum/#!forum/geoodk-community
On Tue, Sep 9, 2014 at 8:00 AM, rahulgupta6oct@gmail.com wrote:
On Tue, Sep 9, 2014 at 1:50 PM, rahulgu...@gmail.com wrote:
On Thursday, 17 July 2014 22:41:02 UTC+5:30, Ryan Behr Atherton wrote:That is a pretty loaded question.
Rahul
Thanks in Advance
Rahul
Rahul--
