Hi All
I would like to customise the text that appears when a required field
is not completed. At the moment, you get the standard "Sorry, this
response is required!" - I would prefer a field-specific message. I'm
not sure if there is another way to achieve this, but I changed the
createConstraintToast method in activities/FormEntryActivity.java to
look as follows:
private void createConstraintToast(String constraintText, int
saveStatus) {
switch (saveStatus) {
case FormEntryController.ANSWER_CONSTRAINT_VIOLATED:
if (constraintText == null) {
constraintText =
getString(R.string.invalid_answer_error);
break;
case FormEntryController.ANSWER_REQUIRED_BUT_EMPTY:
constraintText =
getString(R.string.required_answer_error);
break;
showCustomToast(constraintText);
mBeenSwiped = false;
Now instead of the default text, the constraintMsg property is used if
it is available.
Another question - I don't see any way to translate this text based on
the currently selected language. Is this possible?
Adi
Forgot to mention, due to the way getConstraint works - you still need
to add in a constraint.
e.g. for a string type I have been using constraint=". != ''"
the constraint has to be valid - so for a numeric type, I have been
using constraint=". != -999" (somewhat hackish i know)
I'm not sure what to do for a geopoint type - any suggestions?
Adi
On Oct 2, 7:59 am, Adi Eyal wrote:
> Hi All
> look as follows:
> saveStatus) {
> constraintText =
> break;
> constraintText =
> break;
> it is available.
> Thanks
> Adi
Adi,
I see you have a couple skip logic related questions; you might find it
easier to use a GUI for writing your skip logic. Try this:
http://formbuilder.kobotoolbox.org/KoBoFormDesigner.html
There is a Getting Started tutorial here:
https://sites.google.com/site/kobonaut/getting-started-tutorial
And some specific help about skip logic here:
https://sites.google.com/site/kobonaut/kobo-user-guide/home/skip-logic
Just a tip, you are clearly already working on your survey, you don't have
to start over, just import it into the form designer
Main Menu >> Open From File
Let me know if you have any trouble.
☞§※☼:airplane:
~Neil
On Sun, Oct 2, 2011 at 1:59 AM, Adi Eyal wrote:
Hi All
look as follows:
saveStatus) {
constraintText =
break;
constraintText =
break;
it is available.
Adi
you can also make a question not required, but then do a constraint
regex that checks for blank responses. that'll get it to display the
constraint message without any source code changes.
i don't think constraint messages are localizable, but you can submit
a patch to javarosa-core that enables that. i've filed a bug
http://code.google.com/p/opendatakit/issues/detail?id=352 as a
reminder. feel free to submit the patch there.
> Adi
>> Hi All
>> look as follows:
>> saveStatus) {
>> constraintText =
>> break;
>> constraintText =
>> break;
>> it is available.
>> Thanks
>> Adi
I tried that and it didn't work which is why I went for the above
approach. I guess I got so caught up trying to get my forms working
that I didn't think to ask this simple question. Why doesn't my
constraint below work?
the full test form is below
<h:html xmlns="http://www.w3.org/2002/xforms" xmlns:h="http://
www.w3.org/1999/xhtml" xmlns:ev="http://www.w3.org/2001/xml-events"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:jr="http://
openrosa.org/javarosa">
<h:head>
<h:title>test</h:title>
Test
</h:head>
<h:body>
</h:body>
</h:html>
> a patch to javarosa-core that enables that. i've filed a bughttp://code.google.com/p/opendatakit/issues/detail?id=352as a
> > Adi
> >> Hi All
> >> look as follows:
> >> saveStatus) {
> >> constraintText =
> >> break;
> >> constraintText =
> >> break;
> >> it is available.
> >> Thanks
> >> Adi
the constraint should be != "", not !="
> jr:constraintMsg="This is a required field - please enter"/>
> test
> Test
>> > Adi
>> >> Hi All
>> >> look as follows:
>> >> saveStatus) {
>> >> constraintText =
>> >> break;
>> >> constraintText =
>> >> break;
>> >> it is available.
>> >> Thanks
>> >> Adi
