Hello,
I would like to customize Map on ODK Aggregate.
On the one hand, I will be pleased to set :
- waypoint
- Marker
- circle as Google API v3.
On the other hand, I want to export automatically odk aggregate submission
data.
Thanks for your help.
Hello,
data.
Customizing the mapping capability within ODK Aggregate would require
modifying the software.
There are 3 mechanisms for exporting data from ODK Aggregate.
(1) set up a publisher to an external service ( Google Spreadsheets, Google
Fusion Tables, or other servers accepting XML or JSON POSTs)
(2) use ODK Briefcase to download data from the server to your desktop,
then generate CSV files from that exported data.
(3) export the data directly into a CSV, KML or JSON file.
Hello,
- waypoint
- Marker
data.Thanks for your help.
If you choose the option to stream data to FusionTables, you can use
that table as a layer in Google Maps and do all sorts of
customization. See
https://developers.google.com/maps/documentation/javascript/examples/layer-fusiontables-simple
for more.
modifying the software.There are 3 mechanisms for exporting data from ODK Aggregate.
(2) use ODK Briefcase to download data from the server to your desktop, then
(3) export the data directly into a CSV, KML or JSON file.On Mon, Sep 30, 2013 at 4:07 AM, fofana abdoulaye fofabd@gmail.com wrote:
Hello,
- waypoint
- Marker
mitchellsundt@gmail.com--
