Good afternoon
I would like to know if it is possible to give value to a question in order to add these values at the end of the questionnaire.
Buenas tardes
Quisiera saber si es posible darle valor a una pregunta con el fin de sumar estos valores al final del cuestionario.
Hi @jonnathanCh
Do you mean a value from a previous question? If so yes it's possible. You can create a label in your spreadsheet like The value of the previous answer is ${ans1}
where ans1
is the name of the previous question.
Additionally ans1 maybe not a simple question but a calculation eg. ${ansA} + ${ansB}
you can find more info here: http://xlsform.org/
Hi @Grzesiek2010 what happens is that I have a question and I want to give a value to each answer option and then add them
Ej:
Are you of legal age?
Yes = 20 points
Not = 15 points
he has dogs in his house?
Yes = 5 points
Not = 3 points
and at the end add the scores depending on the answers
Ok, now I understand. Here is a sample form which you can use: calc_scores.xlsx (6.6 KB)
