Can some one please please tell me as STEP by STEP way on how to pre-load
data. I have a very sensitive data which I don't want to upload to the
sever. I have both the CSV files and the Excel file ready but am failing
use them and put them in the right file location for use since I will be
using the manual copying an not the server. Please help help
You need to convert the Excel file to a form definition file (XML) using
the XLSForm converter. Either on the website or via the Windows executable
on the downloads page.
Then, create this directory structure:
..forms\MYFormName.xml
..forms\MYFormName-media\
where MYFormName is the name or formId of your form (after removing all
spaces and punctuation).
Place the CSV and other media files for the form (e.g., form logo) in the
MyFormName-media directory.
Then copy this forms directory onto your device as /sdcard/odk/forms
When you open ODK Collect, it should scan and detect the form, process the
CSV, etc.
On Tue, Mar 24, 2015 at 8:26 AM, Sydney wrote:
Dear all,
Can I use Build module to develop the form and still do the preloading
data? Thanks
> CSV, etc.
> On Tue, Mar 24, 2015 at 8:26 AM, Sydney <sydney...@gmail.com wrote:
>> Dear all,
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Can I use Build module to develop the form and still do the preloading data?
CSV, etc.
sever. I have both the CSV files and the Excel file ready but am failing use
them and put them in the right file location for use since I will be using
Thanks Yaw for your prompt reply.
I am thinking to try to export the form to xml file and then upload it to
Aggregate, along with the csv file. Do you think this would work? I am
wondering how the files are organized on the server...
On Monday, July 20, 2015 at 3:30:54 PM UTC-4, Yaw Anokwa wrote:
> Wen,
> Your best bet is to switch to XLSForm.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> data?
> > Thanks
> using
> executable
> the
> the
> >> CSV, etc.
> >>> Dear all,
> pre-load
> failing use
> using
> Groups
> an
> >> Mitch Sundt
> >> Software Engineer
> >> mitche...@gmail.com
> Groups
> an
Wen,
data?
using
executable
the
the
CSV, etc.
pre-load
failing use
using
Groups
an
Groups
an
I tried the Build model couldn't pass the pulldata function.
As I opened the form I saw 'preload...' but it didn't work as I expected.
This is what I did for the field(A) I expected preloaded data:
pulldata('test','comt','hhid_key',${hhid}), test is the csv file name,
hhid_key and comt are the two columns in csv file. hhid is the form field
where I typed in a hhid_key value from csv file data in order to see the
corresponding comt data populated in the field(A) .
Is above confusing or what did I do wrong?
Wen
On Monday, July 20, 2015 at 4:50:39 PM UTC-4, Yaw Anokwa wrote:
> That would work, but you'd have to make sure your XML conforms with
> https://opendatakit.org/help/form-design/data-preloading.
> Yaw
> to
> >> Wen,
> >> Yaw
> preloading
> >> > data?
> >> > Thanks
> >> >> using
> >> >> executable
> all
> in
> >> >> the
> process
> >> >> the
> >> >> CSV, etc.
> >> >>> Dear all,
> >> >>> pre-load
> the
> >> >>> failing use
> be
> >> >>> using
> >> >>> Groups
> send
> >> >>> an
> >> >> Mitch Sundt
> >> >> Software Engineer
> >> >> mitche...@gmail.com
> >> > Groups
> send
> >> > an
> Groups
> an
Please ignore my previous post. It worked as I changed a data type.
Anyway, can anyone tell me the Build module is definitely not working for
the pulldata() function? The reason I ask is our staff are only trained to
use Build so far...
Wen
> Thanks,
> Wen
>> Yaw
>> to
>> am
>> >> Wen,
>> >> Yaw
>> preloading
>> >> > data?
>> >> > Thanks
>> >> >> using
>> >> >> executable
>> all
>> in
>> >> >> the
>> /sdcard/odk/forms
>> process
>> >> >> the
>> >> >> CSV, etc.
>> >> >>> Dear all,
>> >> >>> pre-load
>> the
>> >> >>> failing use
>> be
>> >> >>> using
>> >> >>> Groups
>> send
>> >> >>> an
>> >> >> Mitch Sundt
>> >> >> Software Engineer
>> >> >> mitche...@gmail.com
>> >> > Groups
>> send
>> >> > an
>> Groups
>> an
Build doesn't (and likely will never) support data preloading. Your
options are to take Build's output and manually edit the XML to make
it support pulldata or use XLSForm. Strongly recommend the latter.
use Build so far...
Wen
Wen
to
am
Wen,
preloading
data?
using
executable
all
in
the
/sdcard/odk/forms
process
the
CSV, etc.
pre-load
the
failing use
be
using
Groups
send
an
Groups
send
an
Groups
an
