Dear Team
I want to restrict decimal value upto 2 digit only is there any way to do this.
Dear Team
Hello Rakesh_Ranjan,
Use a regular expression (https://docs.opendatakit.org/form-regex) as a constraint.
Use regex (.,'^[0-9]{2}') It should work for your case.
Regards,
Dinesh Dongol
Strictly speaking you also need the end-of-line tag, otherwise "12345" will match. And, if "up to 2 digits" means that "1" is OK, then try this:
regex(.,'^[0-9]{1,2}$')
BTW, you can test regex's here
