I'd be happy if someone could help me with this.
I am experimenting with encrypted forms. First, I confirm that the form works just fine unencrypted, and then I add a public key to it. ODK collect collects the form just fine and uploads it to the Aggregate server.
I can download the forms using Briefcase and confirm that unencrypted forms export just fine. However, when I try to export an encrypted form, I get the following error:
Starting Export...
Processing instance: uuid97f707d5-ef2d-46f9-8a49-23dc587b6771
Error decrypting submission uuid97f707d5-ef2d-46f9-8a49-23dc587b6771 Cause: org.opendatakit.briefcase.model.FileSystemException: Error decrypting: submission.xml Cause: org.opendatakit.briefcase.model.ParsingException: Failed during parsing of submission Xml: org.xmlpull.v1.XmlPullParserException: expected: '>' actual: '' (position:END_TAG @1:881 in java.io.InputStreamReader@3c8e7051)
FAILED!
I have installed the unrestricted Java Cryptography jars.
The submission.xml file looks correctly formed to me. I am attaching it in case anyone else can see a problem.
I'm using ODK Briefcase v1.3.2 Production under JRE 1.7.0_25, 64 bit under Windows 7 (64 bit).
submission.xml (1.22 KB)
