- I want to add USGS Natinaol Map topo as a basemap but it is not support
- Offline layer which is store in client mobile storage (Geoodk/layer/..) it is also not suppport (also issue
in MBTILE layer)
Hi @ramtech
it's a problem wit GeoOdk so a better place to ask/report a problem would be there http://geoodk.com/contact.html
As @Grzesiek2010 has mentioned, GeoODK is not part of ODK. I don't believe it's supported anymore.
You can try basemap functionality in ODK Collect by following the documentation. You will need to download ODK Collect.
Thank you mam
Can i see previous point(records) in ODk map ?
I mean if i am using ODK app for Electric pole survey then i want to see previous pole can i see?
Thank you sir
Could you elaborate? What do you mean by previous? You want to see answers from already saved surveys in the new one?
Yes
Actually i want to see placed point in the new one
i am working on get electrical pole information survey so i get one pole information and saved then after new one then i want to see last pole(previous pole) location on the map .
Would that be something like this: geoTest.xml (1.4 KB)
It remembers the answer from the last saved form so if you are adding pints gradually it should meet your expectations.
