My question simply is, when you submit a geo-taggerv2 form on default settings (i.e. not yet set up to a user/server on tablet) where does the data get sent/stored once successfully submitted – it has vanished from my tablet – will I see it published anywhere to get hold of it?
I have checked on the Aggregate page but no sign of my photos – they seem to be from 2011?
The data is likely on http://opendatakit.appspot.com. The data is
sorted by earliest date first, so you will have to press Next a few
times to get to the date you submitted.
Alternatively, map the data and zoom in to your location. You could
also filter by the description you entered or your device ID.
Or, you can apply a filter on the submission date:
(1) check the "Display metadata" checkbox
(2) Add Filter
(3) Choose the "meta-submission-date" field, ">" and enter 2014-11-01 to
see all submissions since November 1st 2014.
On Mon, Dec 8, 2014 at 9:32 AM, Yaw Anokwa wrote:
Hi Emma,
