Whenever I go to the webpage where ODK Aggregate is supposed to be, it just
gives me back a blank page.
Looking at the Tomcat Manager, the ODK Aggregate application isn't running.
Trying to start it gives the message: "FAIL - Application at context path /
could not be started". (I've set ODK Aggregate to ROOT.war in the Tomcat
webapps folder)
What I think are the relevant lines in the catalina.out log are these:
INFO: Initializing ExecutorService 'task_scheduler'
Inside setServletContextafterPropertiesSet WATCHDOG TASK IN TOMCAT
Mar 06, 2017 2:18:08 PM org.opendatakit.common.security.spring.
RoleHierarchyImpl refreshReachableGrantedAuthorities
INFO: Executing: refreshReachableGrantedAuthorities
Mar 06, 2017 2:18:11 PM org.opendatakit.common.security.spring.
WARNING: Datastore failure: refreshReachableGrantedAuthorities -- adjusting
retry time
Mar 06, 2017 2:18:11 PM org.springframework.web.context.support.
XmlWebApplicationContext refresh
WARNING: Exception encountered during context initialization - cancelling
refresh attempt: org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'hierarchicalRoleRelationships' defined in
ServletContext resource [/WEB-INF/applicationContext-security.xml]:
Invocation of init method failed; nested exception is org.opendatakit.common
.persistence.exception.ODKDatastoreException: org.springframework.
transaction.CannotCreateTransactionException: Could not open JDBC Connection
for transaction; nested exception is java.sql.SQLException: Cannot create
PoolableConnectionFactory (validationQuery didn't return a row)
org.springframework.scheduling.concurrent.ThreadPoolTaskScheduler shutdown
INFO: Shutting down ExecutorService 'task_scheduler'
Mar 06, 2017 2:18:11 PM org.springframework.web.context.ContextLoader
initWebApplicationContext
SEVERE: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'hierarchicalRoleRelationships' defined in ServletContext
resource [/WEB-INF/applicationContext-security.xml]: Invocation of init
org.opendatakit.common.persistence.exception.ODKDatastoreException:
org.springframework.transaction.CannotCreateTransactionException: Could not
open JDBC Connection for transaction; nested exception is
java.sql.SQLException: Cannot create PoolableConnectionFactory
at org.springframework.beans.factory.support.
AbstractAutowireCapableBeanFactory.initializeBean(
AbstractAutowireCapableBeanFactory.java:1583)
AbstractAutowireCapableBeanFactory.doCreateBean(
AbstractAutowireCapableBeanFactory.java:553)
AbstractAutowireCapableBeanFactory.createBean(
AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.
getObject(AbstractBeanFactory.java:306)
DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:
230)
at org.springframework.beans.factory.support.AbstractBeanFactory.
doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:754)
at org.springframework.context.support.AbstractApplicationContext.
finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
refresh(AbstractApplicationContext.java:542)
at org.springframework.web.context.ContextLoader.
configureAndRefreshWebApplicationContext(ContextLoader.java:444)
initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.
contextInitialized(ContextLoaderListener.java:107)
at org.apache.catalina.core.StandardContext.listenerStart(
StandardContext.java:4853)
at org.apache.catalina.core.StandardContext.startInternal(
StandardContext.java:5314)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:753)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:
729)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:
1816)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:
511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.
java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor
.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.opendatakit.common.persistence.exception.
ODKDatastoreException: org.springframework.transaction.
CannotCreateTransactionException: Could not open JDBC Connection for
at
org.opendatakit.common.persistence.engine.pgres.DatastoreImpl.assertRelation(DatastoreImpl.java:650)
at
org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.assertRelation(GrantedAuthorityHierarchyTable.java:115)
at
org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.getEntireGrantedAuthorityHierarchy(GrantedAuthorityHierarchyTable.java:186)
at
org.opendatakit.common.security.spring.RoleHierarchyImpl.buildRolesReachableInOneStepMap(RoleHierarchyImpl.java:464)
at
org.opendatakit.common.security.spring.RoleHierarchyImpl.refreshReachableGrantedAuthorities(RoleHierarchyImpl.java:281)
at
org.opendatakit.common.security.spring.RoleHierarchyImpl.afterPropertiesSet(RoleHierarchyImpl.java:132)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1642)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1579)
... 25 more
Caused by:
at org.springframework.jdbc.datasource.DataSourceTransactionManager.
doBegin(DataSourceTransactionManager.java:252)
at org.springframework.transaction.support.
AbstractPlatformTransactionManager.getTransaction(
AbstractPlatformTransactionManager.java:373)
at org.opendatakit.common.persistence.engine.pgres.DatastoreImpl.
assertRelation(DatastoreImpl.java:506)
... 32 more
Caused by: java.sql.SQLException: Cannot create PoolableConnectionFactory (validationQuery
at
org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2294)
at
org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2039)
at
org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1533)
at
org.springframework.jdbc.datasource.DataSourceTransactionManager.doBegin(DataSourceTransactionManager.java:211)
... 34 more
Caused by: java.sql.SQLException: validationQuery didn't return a row
at org.apache.commons.dbcp2.PoolableConnection.validate(
PoolableConnection.java:303)
at org.apache.commons.dbcp2.PoolableConnectionFactory.validateConnection
(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(
BasicDataSource.java:2307)
createPoolableConnectionFactory(BasicDataSource.java:2290)
... 37 more
Mar 06, 2017 2:18:11 PM org.apache.catalina.core.StandardContext
listenerStart
SEVERE: Exception sending context initialized event to listener instance of
class org.springframework.web.context.ContextLoaderListener
method failed; nested exception is org.opendatakit.common.persistence.
exception.ODKDatastoreException: org.springframework.transaction.
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1583)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:754)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542)
at
org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4853)
at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5314)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:753)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729)
at
org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816)
at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by:
at org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable
at org.opendatakit.common.security.spring.RoleHierarchyImpl.
... 25 more
Caused by: org.springframework.transaction.CannotCreateTransactionException:
Could not open JDBC Connection for transaction; nested exception is java.sql
.SQLException: Cannot create PoolableConnectionFactory (validationQuery didn't
return a row)
at
org.springframework.jdbc.datasource.DataSourceTransactionManager.doBegin(DataSourceTransactionManager.java:252)
at
org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:373)
at
org.opendatakit.common.persistence.engine.pgres.DatastoreImpl.assertRelation(DatastoreImpl.java:506)
... 32 more
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(
at org.apache.commons.dbcp2.BasicDataSource.getConnection(
... 34 more
at
org.apache.commons.dbcp2.PoolableConnection.validate(PoolableConnection.java:303)
at
org.apache.commons.dbcp2.PoolableConnectionFactory.validateConnection(PoolableConnectionFactory.java:357)
at
org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2307)
at
org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2290)
... 37 more
06-Mar-2017 14:18:11.322 SEVERE [localhost-startStop-1]
org.apache.catalina.core.StandardContext.startInternal One or more
listeners failed to start. Full details will be found in the appropriate
container log file
Mar 06, 2017 2:18:11 PM org.apache.catalina.util.SessionIdGeneratorBase
createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using
[SHA1PRNG] took [271] milliseconds.
06-Mar-2017 14:18:11.667 SEVERE [localhost-startStop-1]
org.apache.catalina.core.StandardContext.startInternal Context startup
failed due to previous errors
Mar 06, 2017 2:18:11 PM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
06-Mar-2017 14:18:11.906 WARNING [localhost-startStop-1]
org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The
web application [ROOT] registered the JDBC driver [org.postgresql.Driver]
but failed to unregister it when the web application was stopped. To
prevent a memory leak, the JDBC Driver has been forcibly unregistered.
Any help would be appreciated! I've been wrestling with this problem for a
while and can't find what's wrong.
I've tried the following things:
- Re-installed Tomcat 8.0.41
- Ran through the ODK Aggregate 1.4.13 setup several times to make new
ODKAggregate.war files
- Did a DROP DATABASE and DROP ROLE for odk_prod and odk_user in
postgres then ran the create_db_and_user.sql again
- Pointed my Tomcat JVM version (via setenv.sh) from jre 1.8.0_91 to
java-7-oracle, java-8-oracle, and java-7-openjdk-amd64
- Placed the JDBC drivers postgresql-42.0.0.jar and
mysql-connector-java-5.1.41-bin.jar in the Tomcat lib folder
Other information:
- I'm on Ubuntu 14.04.5 LTS
- I'm using PostgreSQL 9.6.2
- The JRE I'm using is JRE 1.8.0_91-b14
- The set-up I was using before that worked just fine was ODK Aggregate
1.4.11 on Tomcat 6.0.45
This is apparently an issue with permissions to the information_schema in
PostgreSQL.
We have only tested Aggregate 1.4.13 on PostgreSQL 9.4 where this problem
does not exist.
The apparent fix is to execute an additional grant in the
create_db_and_user.sql script.
I believe the missing command (you will need to replace the database and
user names with the ones appropriate for your installation) is:
alter database "odk_prod_db" owner to "odk_prod";
just gives me back a blank page.
running. Trying to start it gives the message: "FAIL - Application at
context path / could not be started". (I've set ODK Aggregate to ROOT.war
in the Tomcat webapps folder)
adjusting retry time
common.persistence.exception.ODKDatastoreException: org.springframework.
Connection for transaction; nested exception is java.sql.SQLException:
Cannot create PoolableConnectionFactory (validationQuery didn't return a
row)
Mar 06, 2017 2:18:11 PM org.springframework.scheduling
ence.exception.ODKDatastoreException: org.springframework.transactio
n.CannotCreateTransactionException: Could not open JDBC Connection for
at org.springframework.beans.factory.support.AbstractAutowireCa
1583)
at org.springframework.beans.factory.support.DefaultSingletonBe
at org.springframework.web.context.ContextLoader.configureAndRe
at org.springframework.web.context.ContextLoader.initWebApplica
at org.springframework.web.context.ContextLoaderListener.contex
at org.apache.catalina.core.StandardContext.listenerStart(Stand
at org.apache.catalina.core.StandardContext.startInternal(Stand
ainerBase.java:753)
729)
717)
940)
java:1816)
511)
Executor.java:1142)
lExecutor.java:617)
Caused by: org.opendatakit.common.persistence.exception.ODKDatastoreExc
eption: org.springframework.transaction.CannotCreateTransactionException:
at org.opendatakit.common.security.spring.RoleHierarchyImpl.bui
at org.opendatakit.common.security.spring.RoleHierarchyImpl.ref
at org.opendatakit.common.security.spring.RoleHierarchyImpl.aft
... 25 more
at org.springframework.transaction.support.AbstractPlatformTran
... 32 more
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConne
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(Ba
at org.apache.commons.dbcp2.BasicDataSource.getConnection(Basic
... 34 more
at org.apache.commons.dbcp2.PoolableConnection.validate(Poolabl
... 37 more
listenerStart
of class org.springframework.web.context.ContextLoaderListener
java:145)
ainerBase.java:753)
e.java:729)
java:717)
java:940)
fig.java:1816)
Executors.java:511)
Executor.java:1142)
lExecutor.java:617)
Caused by: org.opendatakit.common.persistence.exception.ODKDatastoreException:
:1642)
1579)
... 25 more
tion: Could not open JDBC Connection for transaction; nested exception is
... 32 more
... 34 more
... 37 more
container log file
createSecureRandom
new ODKAggregate.war files
Other information:
Aggregate 1.4.11 on Tomcat 6.0.45
Hi, Mitch!
That command is already in the create_db_and_user.sql script. I ran it
again but there's no change.
However, your advice helped me figure out an alternative, that maybe the
permission problem itself was with the schema instead of the database. So I
did:
\c "odk_prod_db"
alter schema "odk_prod_schema" owner to "odk_prod";
And that seemed to work!
Thank you very much for your help.
> PostgreSQL.
> does not exist.
> Mitch
>> cancelling refresh attempt: org.springframework.beans.factory.
>> BeanCreationException: Error creating bean with name
>> 'hierarchicalRoleRelationships' defined in ServletContext resource [
>> /WEB-INF/applicationContext-security.xml]: Invocation of init method
>> failed; nested exception is org.opendatakit.common.persistence.exception.
>> java:230)
>> 145)
>> :729)
>> 717)
>> 940)
>> java:1816)
>> :511)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 25 more
>> Caused by:
>> ... 32 more
>> at
>> at
>> at
>> at
>> ... 34 more
>> ... 37 more
>> listenerStart
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> ... 25 more
>> at
>> at
>> at
>> ... 32 more
>> ... 34 more
>> at
>> at
>> at
>> at
>> ... 37 more
>> container log file
>> createSecureRandom
>> org.apache.catalina.core.StandardContext.startInternal Context [] startup
>> a while and can't find what's wrong.
>> 1. Re-installed Tomcat 8.0.41
>> 2. Ran through the ODK Aggregate 1.4.13 setup several times to make
>> 3. Did a DROP DATABASE and DROP ROLE for odk_prod and odk_user in
>> 4. Pointed my Tomcat JVM version (via setenv.sh) from jre 1.8.0_91 to
>> 5. Placed the JDBC drivers postgresql-42.0.0.jar and
>> Other information:
>> 1. I'm on Ubuntu 14.04.5 LTS
>> 2. I'm using PostgreSQL 9.6.2
>> 3. The JRE I'm using is JRE 1.8.0_91-b14
>> 4. The set-up I was using before that worked just fine was ODK
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
