Hi, I'm curious if anyone has experienced this or can explain it. In my
Excel spreadsheet (from ODK Aggregate csv export), one data collector has
164 web submissions via the KoboCollect to ODK Aggregate. But when I got
his phone back at the end of the survey, I did a Briefcase import (Pull)
and it imported 170 submissions - a difference of 6 entries.
So I did a duplicate search on the Latitude field and start date -- none
found!!. Next, I grabbed the Latitude field from the web submissions
(KoboCollect to ODK Aggregate) and pasted it into the Latitude field in the
BriefCase csv (Latitude columun) and then sorted them by Latitude. And I
saw the 6 BriefCase import entries that had no matching web submissions.
Any ideas? The data looks good and definitely these 6 submissions SHOULD be
in the system.
~DataMax
NOTE1: One FAILED submission that was left on the phone was successfully
imported by BriefCase.
NOTE2: The data collectors are instructed NOT to DELETE anything (saved
forms, submitted forms, etc.) -- just in case!
NOTE3: BriefCase error/warning message at startup. It still imported 170
forms without any problems though. Could this be why I was having duplicate
submissions that I raised in another thread?
-------------------------- C:\Program Files (x86)\Java\jre6\bin>java -jar briefcase.jar 16-Jun-2012 12:14:42 PM org.opendatakit.briefcase.ui.FormTransferTable$DetailBut ton INFO: creating details button 16-Jun-2012 12:14:42 PM org.opendatakit.briefcase.ui.FormTransferTable$DetailBut ton INFO: creating details button Parsing form... Title: "Marys Survey" Warning: 1 Unrecognized attributes found in Element [bind] and will be ignored: [format] Location:Problem found at nodeset: /html/head/model/bind
With element <bind id="GPS" nodeset="/Marys_Survey/GPS" format=
"gps" type="geopoint" required="true()"/>
ignored:
[format] Location:
With element <bind id="Pic" nodeset="/Marys_Survey/Pic" format=
"image" type="binary" required="true()"/>
XForm Parse WARNING: unrecognized data type
Warning: 1 Unrecognized attributes found in Element [upload] and will be
ignored
: [mediatype] Location:
Problem found at nodeset: /html/body/upload
With element <upload bind="Pic" mediatype="image/*">
ignored
: [bind] Location:
Warning: 1 Unrecognized attributes found in Element [group] and will be
ignored:
[id] Location:
Problem found at nodeset: /html/body/group
With element <group id="INTERESTS">
ignored:
[id] Location:
With element <group id="INTERESTS2">
ignored:
[id] Location:
With element <group id="INTERESTS3">
Warning: 1 Unrecognized attributes found in Element [Marys_Survey]
and will be ignored: [id] Location:
Problem found at nodeset: /html/head/model/instance/Marys_Survey
With element <Marys_Survey id="Marys_Survey">
