Dear ODKers,
I have been tasked with programming a household survey using ODK
Collect. The survey has the following sections:
- Collect a list of all household members from oldest to youngest.
For each household member ask a number of questions.
- For each child under five years of age ask questions about nutrition.
- For each child-bearing age woman in the household ask about malaria
knowledge.
Given my knowledge of XForms and Collect 1.1.5, I see two approaches
to implementing this survey:
Move all sections into loop #1. As we're collecting information on
each household member, if this household member is a child under five
ask the appropriate group of questions, if the household member is a
child-bearing age woman ask the questions about malaria knowledge.
Have the surveyor maintain a paper list of household members that
assigns ID numbers to each household member. The loops #2 and #3 have
no knowledge of what was input in loop #1 and we rely on the surveyor
to put the right household member IDs into loops #2 and #3.
Any suggestions for alternative solutions?
Andrew
These are definitely the two possibilities in a single form. Another option
is to consider separate forms but that would even have more issues getting
data from one form into another.
Option 1 is certainly the easiest. However, it depends on how many
questions there are about the child or woman. If it is only a few, then
this is definitely the way to go. If the nutrition/malaria questions are
extensive then it may not work so well to dive deep about one person.
Option 2 depends on how well XPATH expressions are supported in JR and
whether you can reference data in different iterations of loop #1 and even
determine how many iterations there were. In practice, though, this
approach isn't all that different than Option 1 as you still have to dive
into the details of each person one at a time.
I would go with 1 unless your field staff complains about the approach.
Gaetano
On Mon, Aug 8, 2011 at 1:45 PM, Andrew Marder wrote:
Dear ODKers,
knowledge.
Andrew
Hi Gaetano,
Thanks for the quick feedback.
The part I haven't figured out is how to get a counter in the repeat.
For instance if I was writing this in Python I would do something
like:
members =
while household has more members:
members.append( new household member )
for i in range(len(members)):
if members[i].age <5:
ask questions for child under five
The XPath I need to access will look like /household/member[i]/age. Is
this currently possible?
Gaetano
On Mon, Aug 8, 2011 at 1:45 PM, Andrew Marder andrew.ei.marder@gmail.com wrote:
Dear ODKers,
knowledge.
Andrew
To solve a similar problem we used relative paths,for eg.
../age<5
Regards
Deepak
Hi Gaetano,
option
getting
even
> like:
> members = []
>> Gaetano
>> On Mon, Aug 8, 2011 at 1:45 PM, Andrew Marder >>
>>> Dear ODKers,
>>> 1. Collect a list of all household members from oldest to youngest.
>>> 2. For each child under five years of age ask questions about nutrition.
>>> 3. For each child-bearing age woman in the household ask about malaria
>>> knowledge.
>>> 1. Move all sections into loop #1. As we're collecting information on
>>> 2. Have the surveyor maintain a paper list of household members that
>>> Andrew
>>> Post: opendatakit@googlegroups.com
>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>> Options: http://groups.google.com/group/opendatakit?hl=en
