I am trying to save the number I assigned to each of devices to my
instances. I can get the guys to just enter it manually, by looking at the
sticker on the back, but I figured it should be possible to run the
deviceid through a pulldata() function to automatically retrieve the number
from a list. However, it seems the device id depends not only on the
device, but also on the form being used: different forms will assign
different deviceids on the same machine. Is this behaviour intentional? And
if so, is there any other way to do this apart from the manual way?
Would/should this not be exactly the same as the "deviceid" type in
XLSForm?
On Thursday, June 26, 2014 12:15:35 PM UTC+2, Ayub wrote:
> Try this bind for
> jr:preloadParams="deviceid"/>
> This consistently gives me same id for any number of forms. i.e. device
> imei number.
Hmmm... this is what I am using, and I am certain I've got devices with
different deviceids in different forms.
I am using ODK 1.4.3 on Acer Iconia B1 tablets running Android 4.1.2 by the
way.
On Thursday, June 26, 2014 3:48:19 PM UTC+2, Yaw Anokwa wrote:
> Yes, this is the same.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Thu, Jun 26, 2014 at 5:29 AM, Koen <koen.l...@gmail.com > wrote:
> > Thanks.
> XLSForm?
> >> Try this bind for
> >> imei number.
> Groups
> > "ODK Community" group.
> an
Device ID reports either the cellular IMEI, WiFi MAC address, or
Android ID (a unique identifier assigned by the operating system).
What gets reported depends on the device.
Your email doesn't really explain what the problem is, so the more
details you can provide, the better.
Groups
an
Sorry if I wasn't clear. Kind of stressed out, and it shows from the
messages I've been typing here. But anyway: from your message it seems that
if I fill in two different forms on the same tablet, I should get the same
Device ID, right? Well, I get a different deviceid for different forms, on
the same tablet. This is not the behaviour I anticipated.
Koen
On Friday, June 27, 2014 4:08:45 PM UTC+2, Yaw Anokwa wrote:
> Koen,
> Yaw
> the
> > way.
> >> Yaw
> >> On Thu, Jun 26, 2014 at 5:29 AM, Koen wrote:
> >> > Thanks.
> >> > XLSForm?
> >> >> Try this bind for
> device
> >> >> imei number.
> >> > Groups
> send
> >> > an
> Groups
> an
Koen
Koen,
Groups
send
an
Groups
an
This would be extraordinary behavior for any device and I think that people
may be having a hard time quite believing it. You might want to
triple-check to make sure that you're not being confused by data from
multiple devices, old data, etc. Then, you might do some work to try to
figure out from where these various device ID's are coming. Perhaps you are
getting the Wifi MAC address when connected to Wifi but the IMEI when not?
You should be able to look deeply into the ID's you're getting to figure
out how your device is behaving.
Chris
Koen
Koen,
Groups
send
an
Groups
an
On Fri, Jun 27, 2014 at 8:36 AM, Christopher Robert wrote:
Koen,
people may be having a hard time quite believing it. You might want to
Koen
Koen,
Groups
send
an
Groups
an
Thanks all, it must be that sometimes the MAC address is stored, and
sometimes the Android ID.
I've been trying to get different device ID from different forms, but
obviously this has failed so far to get it to show up on purpose. So I've
been going back through all my device data to find one that has been used
extensively. In a classroom setting, which would have wi-fi access if there
was power at the time, this device id was assigned: 98:ff:d0:4b:6d:c0. This
looks like a MAC address to my untrained eye. When the same device was
taken to the field (no wi-fi) it displays 4596fce2ce7f7a5d, which seems
like it could be an Android ID.
Is there any way to force which number is being stored? In general, my guys
shouldn't be near any wi-fi hotspot when doing their work, but I'd rather
be 100% sure.
Koen
On Friday, June 27, 2014 5:42:18 PM UTC+2, Mitch Sundt wrote:
> Echoing Chris...
> Is this for both forms under the same conditions? i.e., same wifi
> connectivity, same cellular reception, etc?
> If so, for a given tablet, what ids are you seeing? Is it IMEI, MAC, or
> AndroidID?
> You can change the deviceid jr:preloadParams to uri:deviceid and it will
> prefix the id value with the designator of which one is being used.
> http://opendatakit.org/help/form-design/examples/#Property_values
> On Fri, Jun 27, 2014 at 8:36 AM, Christopher Robert <cro...@surveycto.com > wrote:
>> Koen,
>> Best,
>> Chris
>> On Fri, Jun 27, 2014 at 11:29 AM, Koen <koen.l...@gmail.com wrote:
>>> Hi,
>>> Koen
>>>> Koen,
>>>> Yaw
>>>> with
>>>> by the
>>>> > way.
>>>> >> Yaw
>>>> >> > Thanks.
>>>> in
>>>> >> > XLSForm?
>>>> >> >> Try this bind for
>>>> >> >> >>> jr:preload="property"
>>>> device
>>>> >> >> imei number.
>>>> >> > Groups
>>>> send
>>>> >> > an
>>>> Groups
>>>> send an
>>> Groups "ODK Community" group.
>>> an email to opendatakit...@googlegroups.com .
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
As a workaround, maybe add a question that asks enumerators to enter
their enumerator ID. Or maybe have them create Google accounts and add
a uri:email question (See http://opendatakit.org/help/form-design).
looks like a MAC address to my untrained eye. When the same device was taken
to the field (no wi-fi) it displays 4596fce2ce7f7a5d, which seems like it
shouldn't be near any wi-fi hotspot when doing their work, but I'd rather be
100% sure.
Koen
Echoing Chris...
AndroidID?
You should be able to look deeply into the ID's you're getting to figure out
Koen
Koen,
Groups
send
an
Groups
send an
there
This
taken
guys
rather be
100% sure.
Koen
Echoing Chris...
AndroidID?
On Fri, Jun 27, 2014 at 8:36 AM, Christopher Robert < cro...@surveycto.com> wrote:
Koen,
you are
not?
figure out
seems that
same
forms, on
Koen
Koen,
Google
Groups
it,
send
an
Groups
send an
Groups
an
