Direct transfer of data and forms between Central servers
Hello all.
Can you please tell me whether there is a direct way (e.g., via the command line) to transfer data and forms between Central servers ?
Thanks in advance for your replies.
Regards
Can you please provide some more details about your use case? For example: Is this a backup and restore situation? Do you want to migrate everything, or just some of the projects? Does the server you're moving to have other projects on it already?
Thank you for your reply.
I intend to migrate everything from an existing server to a new an empty server.
Regards
Trying to migrate my ODK deployment and its data from AWS to Digital Ocean - #2 by yanokwa has guidance on how to move data from one server to another server.
The above link assumes you aren't changing hostnames. If you are, the process is a lot more complicated because you'll have to find and replace the hostnames in the Redis databases that Enketo uses.
@danbjoseph ,
Thank you so much for the resource.
I will give it a try.
Regards
