Hi you guys,
I'm wondering if the GPS Coordinates screen in ODK Collect could be customized to display Decimal coordinates instead of Degrees-Minutes-Second when the location locks-in?
If so, what would be the best way of coding this using XLSforms (or is it a switch in options menu)?
Thanks a lot!
You would have to modify the Java code.
Then you would use/define different appearance strings for the geopoint
field to inform the Java code that it should show decimal coordinates.
On Thu, Jul 25, 2013 at 2:43 AM, wrote:
Hi you guys,
Thanks a lot!
