Hello all.
we are working on a project where the phone needs to display the
questions and radio buttons in the native language (Nepali). I tested
this function by translating the of the Label and Hint into
Spanish, and it worked great. Its almost like a built-in translator
if the form is all radio buttons.
Now its time to insert Nepali characters. I am using unicode in a
format of &#nnnn;
it doesn't work. The form does not show on the gather app, even
though I can see it saved on the sd card.
Any one else have success with displaying non-Roman alphabet
characters in the forms?
Thanks in advance. I find the answers to so many of my questions by
keeping up with this group.
if spanish characters are working but nepalese characters are showing
up as square boxes, then there is a font problem -- we probably cannot
solve that. the alternative is to use the image as prompt text to use
pictures of the text (rather than the text itself). see the new
widgets form at http://code.google.com/p/opendatakit/source/browse?repo=forms for an
example.
if the form itself isn't showing up in the phone, then there is
something else going on. make sure the form validates with odk
validate.
> format of nnnn;
On Dec 14, 6:19 pm, Yaw Anokwa wrote:
> attach the form tohttp://code.google.com/p/opendatakit/issues/detail?id=477and we can
> take a look. please also describe the version of collect you are using
> and the version of android (hardware and software).
> widgets form athttp://code.google.com/p/opendatakit/source/browse?repo=formsfor an
> example.
> validate.
> > format of nnnn;
face = Typeface.createFromAsset(getAssets(), "DDC_Uchen.ttf");
tv.setTypeface(face);
There is also some extracode in the sample for dealing with the
stacking/subscript issues that are problematic for some languages.
Perhaps ODK could include the ability to specific a custom typeface?
Nathan
On 12/14/2011 12:29 PM, Alex Little wrote:
> We've successfully got ODK running with Ethiopian font, though as Yaw
> described the real issue was teh phone not having the correct font to
> render teh text correctly.
Shemechanik,
If Nepalese font is like other Indic Font that needs combined letters -
then only Font file (even rooting and changing system fonts with unicode
fonts files) may not solve the problem - you may need a shaper that shapes
the correct typeface - we did Bengali in Android phones by some customized
shaper and widgets - if you can send me a Nepalese True Type Unicode
supported font I may check whether you will need a shaper or not.
Sami
I've done some work in helping get Tibetan support working on Android,
specifically without requiring a rooted or rom'd device.
Here is an example of loading a Tibetan font for use in a simple textpad
application, and setting the typeface for a TextView element:
